The Stumpy Nubs Workshop
Tags
bandsaw bill pentz biscuit joiner block planes box joint jig box joints burnisher business cabinet doors cabinet scraper card scraper central machinery dust collector charles neil chisel clamp clear vue clear vue cv1800 clear vue cyclone clearvue cyclone cnc woodworking crosscut sled dmt diamond stones downdraft sanding drawers drill press drill press table drum sander dust collection dust collection duct work earlex 5500 spray station festool cms festool domino finger joint jig finger joints frame and panel furnace blower filter grago truecoat pro grinding jig hand planes harbor freight harbor freight dust collector harbor freight electric planer harbor freight hvlp gun homemade drum sander homemade jigs homemade router lift homemade table saw sled homemade tools horizontal router table humor idea incra incra lite incra ls jig saw jigs joining jointer kreg jig kreg shelf pin jig lathe leigh super fmt maple milling oak oil stones particle board pen turning pinnacle positioner plan plane planer project progress radial arm saw raised panel review rockler shelf pin jig rockwell blade runner router router boss router fence router jig router lift router table roy underhill sander scary sharp scraper till sharpening shelf pin jig shop lighting skill splined miters stanley 3 stumpy nubs table saw sled tablesaw tenon jig the woodwrights shop thien baffle tip tool rest tool stand tormek traditional trick tutorial tutorial stumpy nubs video walnut water stones woodrat work sharp 3000 worksharp wynn filters
508K views 1.1K replies 230 participants last post by  Desert_Woodworker
#1 ·
FINALLY- The first episode is done! You're gonna LOVE IT!
Maybe "LOVE" is a strong word. But I'm really excited about the final version of the show, and I think most people will feel the same way.
Forget about everything we experimented with before. This is all new. It's been over a year in development, and And I'd like to think it is a pretty unique format! Here's how it works…
The show is designed to have the feel of a single camera "reality" type show. It is meant to be a glimpse into our workshop as if you were just stopping in every week to see what's going on. Projects are always in progress, but not really a "start to finish, one project per episode" kind of thing like most other podcasts. Each episode will flow into the next. For example, the first episode (split into four segments) documents all of the chaos going on in the shop as a couple of important projects move from design through completion. It's hard to describe, but after the first couple episodes I think everyone will get a good feel for the uniqueness of our format.
It's also a lot shorter. But, since we didn't want to cut down on the content of each episode, we just split the episode up into four weekly parts. This week is Episode 1, part one, and next week is part 2, and so on. This will allow us to keep the special segments we wanted, like tool reviews, shop tours, a bit of comedy, and a lot more.
So, watch the first episode, tell me what you think…
QUICK RUNDOWN OF EPISODE 1 PART 1:
Most of the time is spent on a unique mini traditional woodworking bench for a small shop. In the meantime, Stumpy begins work on his design for the Charles Neil Throwdown.
(Part 2 is already finished, so this should begin a series of regular, weekly releases instead of big gaps between parts)
#54 ·
First Stumpy I LOVE IT. I think you did great. I liked the content, humor and it keep my attention. I am a bitt of A D D. And you had me the whole time. Don't change a thing. We need another good pod-caster.
Stay yourself it was great and real.
I hope you beat Charles. I always go for the underdog.
#58 ·
I thoroughly enjoyed you video Stumpy. After reading the safety debate comments though, I had to go back and watch it again. I wouldn't have noticed any of that if someone had not have pointed it out. I guess I never need to make videos, because I am not a safe wood worker. You use more safety awareness than I do on my best days. I fall into the stubborn ass category. I feel that we take, to a point, a measured risk every time we walk out of the house in the morning. I use common sense when doing anything, including wood working. To me though, if I have to overthink every situation as if it were my last, I would rather go crawl back into my bubble and never take any risks.
Please understand I am not encouraging anyone not to use safety. I only say to do what you are comfortable with. If you are uncomfortable doing any process in the wood shop, you need to back up and think about it. In my opinion, being scared of a machine, or pocess, will cause you injury quicker than not using such and such safety technique will.
In my honest opinion, all accidents in the shop fall into one of four categories, improper knowledge of what one is doing, carelessness, failure to properly maintain equipment, and being nervous about a procedure to the point of not having business performing the operation in the first place.
I apologize if I offend anyone with this analysis. It is only my opinion. If it bothers anyone, then watching me in my shop would probably give you nightmares.
#63 ·
Reading all the safety comments has now given me a new idea for the 2×4 contest….an 8' push stick
I would tend to agree with Steve that actual footage of cutting a board need not be much longer than a second. I do wish more woodworking shows would spend a bit more time explaining how they set their tools up for the cut.
As far as inspiration… your project for a narrow woodworking bench has given me an idea for when I add about 6" in depth to my existing workbench to go over where my new drawers stick out (see my projects).
I had no problem with the audio and liked the overall format. I would probably suggest you turn the news off while you are shooting the video.
#64 ·
Enjoyed it Stumpy. Will continue to watch. Sometimes I use Gloves also. Carvers finger leathers at times. Hold up better than skin. Educated choices. Sometimes a wet rag on the fence to freshen finger traction. Kudos overall. What is safe for some is not safe for all. You looked comfortable with your tools. Too many people are not. Like it or not their tools scare them.
Be professional, careful and safe.
If you haven't had a close call you ain't been there.
#65 ·
You NEED this mini-cabinet maker's bench! (Part 2)
The camera comes back into the Stumpy Nubs Workshop to further document life in a small semi-professional shop…
Includes tips on hand cut dovetails, utility chisels, resawing wide boards on the table saw, glue-ups, and a lot more!
This is part 2 of Episode 1. It begins with making the CN Box, then continues the "amazing mini-cabinet marker's bench".
My favorite part is the footage on cutting tiny dovetails by hand, big ones by machine, and huge ones with a honkin' chisel!
Also included is the first of many "mini-tool reviews".
Enjoy!
#100 ·
Shop tour! YAH BABY! (Giant Sanding Machine & More...)
Episode 1 part 3 is about shop efficiency, so we take a look at our workshop and make some layout changes. PLUS, we make some changes to the GIANT SANDING MACHINE and the mini-cabinet maker's bench nears completion. Throw in a bench vise review and some other stuff, and you have a pretty fast moving ten munites!
This is the last part of episode one, and we are still working out some kinks with the software and audio systems. Give it a few episodes before demanding perfection…:)
#127 ·
Time to heat the shop already? + some light humor
This week the cameras catch us installing gas heating in the workshop and we share some of the tips that help us make multiples of the same project fast. Plus, we review the new Trend blade cleaner and their 60 tooth blade and wrap up with the return of the humor segment: "Stumpy's Evening Advice"- where you learn how to get out of making projects for people
By the way ditched the complicated four part per episode numbering system (1-1-2, etc.). You're welcome…
#155 ·
OUR BEST EPISODE YET- If I do say so myself...
If you haven't seen the show yet, this may be the episode to start with. It's fast moving, introduces a great project, and features the twisted sense of humor that makes Stumpy Nubs videos unique.
This week the workshop finds itself designing a clamp rack that will hold 48 clamps in just 3X2' of wall space.
Then Stumpy reviews "stretchy tape" (whatever that is…)
And finally (my favorite part) Stumpy tries to figure out how to get out of trouble with the wife over buying an expensive new tool. (Funny stuff)
#156 ·
Hey Stumpy!
Thank you ever so much for that fantastic Nail Tip!
Now, I will have to spend a lot of time sorting my nails as to what side the house they go on!
What a great way to spend your time on when snuggled in front of a nice warm fire!
Thank you again! Great Tip!
The rest of the Video was good too…
Merry Christmas
and
Happy New Years!
#178 ·
Who said Stumpy isn't very sharp?
What do you get when you combine unlimited resources with the greatest woodworking mind ever? This week Stumpy demonstrates the opposite of that…
Stumpy turns his Work Sharp 3000 into a super-duper sharpening machine that works without sandpaper and accepts Tormek jigs. Then turns his sarcasm and twisted humor loose on the viewer emails. (Who knew handplanes and popcorn had so much in common…)
This is part one of a 2 part sharpening series. Next week we make some fully adjustable, sliding grinder tool rests, make our own Tormek jig, and show you how to get a Tormek style wet sharpening system for about $50!
#205 ·
Stumpy I want your gold wrench. And we are going to have to do something about rust control on your saws. On the subject of animals, today my cat comes in the shop while I am soldiering copper wires to re-bar. It didn't get him bad but his new name is saftycat. Poor thing, but I keep telling them get out. Being a cat they just look at you like [who me].
Great video and a very nice jig. I tried this with an articulated arm. It wound up to bulky. I like your jig with the purchase of the veritas rig. Another good one with tips, jigs and humor. Well written and done. Keep em coming.
#209 ·
Now that's just plane smart! (Hand plane surgery and tubafores)
What to do with a couple old, useless hand planes? This week Stumpy takes a hack saw to a pair of Stanley's and a rabbet plane is born!
And what's a tubafore? Stumpy tames one, and it makes him feel like a real man!
Finally, we rant about the new fangled technology in the workshop.
Enjoy!
#223 ·
A night as big as the Oscars! "TUBAFORE" CONTEST RESULTS!!!
It's a night so special that Stumpy put on a tie!
The latest episode of Blue Collar Woodworking reveals who won the 2X4 contest, who lost, and who the heck is that guy in the wizard outfit…
It's twelve of the best minutes you're likely to spend today… enjoy…
#254 ·
Homemade Biscuits and the ULTIMATE tool cabinet!!!!
In this episode we unveil our shop-made bench top biscuit joining machine designed for fast, accurate glue-ups… and we begin the "Ultimate Tool Cabinet Build". Plus, Stumpy gives you a list of things to do with your Sundays now that football season is over…
Here's some screen shots of the sketchup drawing for the machine. The most difficult part about the build was the mount for the joiner. It took a lot of work to get the design just right. If it's not right, the movement is not accurate.
The lift adjustment mechanism for the table had to be redesigned a couple of times tool. But I finally found the proper way to address all of the issues that contribute to accurate adjustments.
A set of plans is available in our Etsy store ... check it out and help support our show!
#255 ·
I'm the 1st one here…....... yeee haaaa I haven't watched it yet, cuz I'm typin this message.. gotta go watch
#294 ·
The "Amazing Dovetail Machine" and why are tools so expensive?
It's new, it's improved, the quality is better, the sound isn't that great… Yes, it's another episode of the woodworking show that makes Norm little series look like Teleubbies…
In this episode we introduce a fully featured, micro adjustable dovetail jig that is so epic, it can only be called a "MACHINE"! And then I rant about how expensive some tools are.
Enjoy… (More episodes are at Stumpynubs.com!)
Want to build it? Here's the plans.
The next episode will take a look at the other side of the issue- my tried and true techniques for hand cut dovetails… and how to fix them when you screw them up!
Oh… here's those $75 hunks of rubber.
#295 ·
Looks like a COOL jig!
How long do you think one could make one… from your plans?
... approximate Cost of materials?
Thank you.
edit:
I had no problems viewing the video at all…
#328 ·
Pins vs Tails and the 2 handled dovetail saw!
Part two of the dovetail series shows how Stumpy cuts 'em with a 2 handles saw! Lots of great tips, and the twisted humor you've come to expect.
(Note- We're still trying to figure this new software out. Sorry for the quality inconsistencies. And the new microphones are on the way!)
Just in case you missed part one of our 2 part dovetail series… here's a re-run! (This is the homemade dovetail machine episode from last week.)
#329 ·
One more or the books Stumpy. I do like to see how people cut there tails. No two guys are alike. If you are taking a vote I am Tail first kinda guy. I gata ask, did I see you using a mortice chisel on waste removal?
Great video!
Keep them coming.
Stumpy I want you to know my wife had laid down for bed and your opening came on. After the punch line about Pooh, she came out from under the cover and I had to assure her you were joking. Now that was funny.
