776K views 1.9K replies 162 participants last post by  Ecocandle
#1 ·
New Year...New Hobby
I have been known to take up a hobby or 37. At 42, on the cusp of 43, and well into the 'balding' years, I have decided that, in lieu of a midlife crisis, I would take up woodworking. Don't get me wrong, a new car and a 27 year old with huge, firm, hands would be wonderful; But I can't afford the 27 year old, and I am not into cars that much.
In the summer of 2009, I went to an arts festival in Des Moines. The gentleman, who won best of show, did so with some amazing etched clay bowls. I am not sure why those clay pots inspired me to take up wood working, or if they were the only inspiration, but shortly thereafter I found myself living in the thriving metropolis of Martelle Iowa. I had my first ever basement.
Without a lot of money to buy all that one needs to build furniture, I started with magazines. The first one was called, "Start Woodworking", from the editors of Fine WoodWorking. I read tips on tools, ideas for projects, stories about great woodworkers, and I began to formulate a plan. I would start with a workbench, the workbench on page 24. The editors of the magazine did a good job of designing a project with the beginner in mind. They even provided a DVD with instructions that were really helpful.
The bench took several months to complete, though the plans were designed so that one could complete it is a weekend. I would guess that I spent 5 hours of thinking about building the bench, for every hour of actual working on it. I thought about what I needed to complete each step, but I was always only focused on the next step. The first step was to buy the 2Ă—4s, 4Ă—4s, 3/8" threaded rod, and a miter saw. Not an electric miter saw, a cheap manual one. I could afford it, it would cut, and I didn't at all care about how long it would take to make each cut. I also discovered in the garage and old hack saw that I could use for cutting the threaded rod.
With the wood cut, I decided I wanted to sand my lumber. The next purchase was a small Black and Decker 'Mouse' sander, some 80, 120, 180 grit sandpaper, and a cool looking level that I didn't need but it was shiny and I was powerless to NOT buy it. The next few weeks found me sanding each piece a bit each day. Barely into my first project I was already getting addicted to the process. The feeling of the construction grade lumber in my hand, after it had been sanded, gave me the slightest glimpse into the beauty of working with wood. I thought about how it must be to run my fingers across a piece of glass smooth mahogany or birds eye maple.
The plans required that I route a 3/8 inch groove into the stretchers. Before I read this magazine I didn't even know what a router or a stretcher was. Each new term learned, each skill set explored, opened up the possibilities that developing woodworking skills offers. And each discovery brought the reality home that care needs to be taken to master each aspect of woodworking. So before I could move on to routing I needed to do a bit of research. This is how one turns a 2 day project into a 2 month quest.
I read reviews and comments. There are many good routers to choose from and I decided to go with the Bosch 2.25 hp router with both the plunge base and the fixed base. I bought 3 bits. A 2" Spiral Downcut CL 2BB and a straight 3/8" by Amana Tools, and a 3/8" Up Spiral bit by Freud. I have come to the conclusion that Freud and Amana Tools are the two best out there. Admittedly Amana makes 2 levels of router bits, and I can't speak to their low end line, but the high end bits have been a joy.
With the router in hand, I had all the tools required to build my workbench. Each step was approached with a sense of confusion and fear. The first time I used the router I was filled with trepidation and pizza, as it was after dinner when I gave it a try. I spent close to 40 minutes setting up a guide for my router. Pieces of 2Ă—4 clamped with 2 24" and 2 36" Jet clamps on my make shift workbench, allowed me to position the router to route. I had read that it is best to take several small passes for safety. Since I was already a bit scared that the router would spin wildly out of control and drive itself into my spleen, leaving me bleeding and generally disappointed, I decided that small passes were a good idea.
It worked as advertised. My first 2 passes made a wonderful 3/8" grove in my wood. I was filled with pride and sure that I was well on my way to being one of the greatest woodworkers of the last 700 years. My second board didn't go as well. I had tightened the collet on the router, though apparently not enough and it had slid up slightly. This had produced a slight up ramp for the groove. My ego needed this set back and I retightened it and decided that I was the greatest woodworker in my basement at that moment. This was good enough for me.
The rest of the project required gluing 2 pieces of Âľ " ODF together to form the top, drilling some holes in the 4Ă—4 legs, and attaching the 9" Jet vice. The only difficult part was installing the vice as it didn't come with instructions, but my own insecurity about getting it right, made me take it at a glacial pace. When I flipped the bench back over and put a piece of wood in the vice, I almost wept with joy.
At the end of the quest I learned several things. 1) When marking wood to be cut or drilled, avoid doing it while watching college football. My bench still bears the scars of several errant holes. 2) Drilling holes with a hand drill, so that they are straight, requires a bit of practice. 3) High quality drill bits are much easier to use than really old, worn out, dull, bits. This likely applies to all tools, the better the quality, the better the results. 4) Fostner bits are cool. 5) I love my workbench, with its shiny red Jet 9" vice. 6) The journey before me is perhaps the most exciting one I have undertaken in my lifetime.
#1,100 ·
#1,102 ·
After A Break
Hello All,
After taking a break from woodworking last night, I got back at it with vim and no small measure of vigor. I chose to talk about woodworking in tonight's woodworking blog post, something that has been a bit rare this week. So I made a bit of progress and made it past the point of my previous blunder.
Brian
I am also testing out Digg. So this is a Digg link. This means you have the ability, if you like the post, to 'Digg' it. I am not suggesting that you will like it and in fact, I offer no guarantees. Truthfully this is probably a middle of the road post, and may not be worthy of a Digg. I leave it up to those that choose to go read it.
http://digg.com/d31PqxR
#1,103 ·
Progress on the Jig
Hello All,
Tonight I have gotten the jig to the point that one can sort of tell what I am trying to accomplish. For those who have been following the jig, it has been pretty much a mystery what I am actually doing. Though I am not done, I did get a bunch done today.
http://extremelyaverage.com/2010/04/a-good-night/
Brian
#1,104 ·
Really? 4 hours and I am not done yet.
Hello LJ folks,
Today I bought some marble tiles, spray glue, wet dry sand paper and made sharpening slabs. I have seen many people suggest that this is a good precursor to the wet stone. So I started on the 180 grit. Now 4 hours later the back of the spokeshave blade is still not done, and I have swapped out the 180 for another piece. In the videos it always looks like they get it done rather quickly. Perhaps it is me.
So that is what I blogged about tonight. If you are curious to see what 4 hours of 180 grit will do to an antique spokeshave blade, feel free to check out the photos.
http://digg.com/d31Q0W9
ok, back to the blade. I will finish it eventually.
Brian
#1,105 ·
Hi Brian,
When lapping the back of a blade or restoring a bevel you need to go to the coarsest grit that will get the job done. If there is stiill a low spot on the back of blade after a couple of minutes go coarser by one grit (150). If after a minute at 150 there is still a low spot go to 120. You may need to go as low as 80 grit to get if flat (you'll have been really unlucky with the blade). Once you've got the coarest grit that flattens the back you can then back up the grits really quickly. Don't forget to change angle at whcih you lap the blade between grits. When you've removed the 45 degree striae with a 90 degree rub you're done at that grit.
This is a situation is when sticky back sandpaper is your friend. I use the Norton Champagne paper and it works well. It's spendy (around $40 a roll) but a roll will last a long time. If you live near a marine chandlery (I do) you can buy it by the foot.
Rather than a tile I'd suggest looking for some 1/4 plate glass (not tempered) and get several pieces - 12"x6" and a 12"x12". I'd use the first as a lapping plane and the second as a honing plate. Being able to stick down multiple grits at once can save a lot of time.
Good luck
Tim
#1,110 ·
More sharpening today...and I love it.
Hello LJ,
DLMcKirdy left a comment on my blog post. I am not sure if he is a LJ or not, but since I still get many readers from here, I thought I would mention that his comment was very helpful. I suspected that I might have started at a grit that was too fine yesterday, and he gave me his rule of thumb for deciding. I took his advice today and had much better results. I really love sharpening stuff now! I am going to sharpen everything I can get my hands on, chisels, planes, carving knives, and even the neighbor's cat, if I can corral him.
Anyway, tonight's rambling is now up, for your dining and dancing pleasure.
http://bit.ly/cyJg2u
Brian
#1,111 ·
hello Brian I didn´t made a comment on your struggle with sharpening
becourse McKirdy already had covert the issue very well
and I´m glad to hear you get along with it now
I also struggled a lot with it before I discovered the nets possibillety
of learning a lot of people how to and why in the different sites
but if you don´t know it yet there is a bunch of small vidio clip on you-tube
about sharpening and how to set up the different planes and other tool as well
I do have the same feeling using a handplane I gess if you are adicted to hand
tools everybody has the same feeling when they see the result of the first
full shaving on a board
take care
Dennis
#1,112 ·
Today I Planed
Hello LJ,
I did some practice planing today, using my Stanley 220. It is obvious that I have a ways to go before I am profecient with hand planes, but I can tell you, I am completely in love with them. Since there isn't much one can write about, when all they did was make shavings, I did a bit of creative writing as well. I hope it is somewhat enjoyable.
http://bit.ly/cplmTr
Brian
#1,118 ·
I have started my first drawer.
Hello LJ,
I feel that it is time to tackle the drawer. A fairly important skill to have, and I have been practicing dovetail joints, so I am going to give it a shot. Today I cut the pieces, did some planing, and started to cut the pins.
http://bit.ly/am6BAk
Brian,
p.s. I am just curious, most days there are between 100 - 200 people who click on my LJ post, and yesterday there were 750. If anyone who reads this, is one of the non regular readers, could you please leave a comment and explain why yesterday was so interesting. I can't see it myself, it looked like the same old drivel to me.
#1,124 ·
I really must give you points for doing all that practicing ! I have a "General Dovetail Jig" for over three years, I have not made myself the time to use it. I bought it at a tool shop back WEST, (ON SALE)Those red tags saying "ON SALE" really weaken me. Sounds like you have fun learnig and writing about the tools you have. Keep us posted , I truly enjoy reading about it.
#1,129 ·
Good call. If your heart ain't in it , WHY DO IT ? Without even knowing it ,you just gave some very good example. Why push yourself to do a job with dangerous tools when you are not completely i"nto it". That is when accidents seem to happen. Have a good week-end in Des Moines !
#1,132 ·
Antique Hand Planes
Hello LJ,
Tonight I am late, because I have been looking and purchasing some beautiful hand planes. There were some that were well beyond my price range, but if you like extremely rare planes, I describe a few of them, and I could put you in contact with the gentleman.
http://extremelyaverage.com/2010/05/acceptable-excuse-for-late-post/
Brian
#1,136 ·
fishing with rod and reel is an art to master
and to restore a plane to be a good user can be a chalange but is artistic in it self
so they cuold very well have met in West Des Moines at the gallry looking at Picaso
for the cheisel you shuold have snaped it , you cuold use a drill (the poor mans lathe)
or use drawknife and spokeshave to make a new handle
give your mother a plesent day she deserve it , after all she raised you lol
Dennis
#1,140 ·
Happy Mother's Day
Hello All Mommy LJ's…and the rest too,
I had a nice day with mom and dad. Then when I got back home I did some practicing on my 100 line cuts. 20 cuts down and I am happy thus far. I included a couple of pictures. I hope you enjoyed the post, it was a better than average one, if I do say so myself.
http://bit.ly/aVbmcz
Brian
#1,145 ·
Your Horoscope is ready...
Hello LJs,
Many years ago, I started to write as a way to entertain my friends at GEICO. I would often compose a set of horoscopes and send them to the those with an odd since of humor. Tonight's blog discusses my continued practice with cuts, but quickly degrades into a set of horoscopes. I hope you enjoy.
http://bit.ly/aEKJsr
Brian
#1,166 ·
3 hours of lapping seems pretty extreme. What grit are you using? It looks like you are using wet and dry. I'd recommend considering using much coarser grits. I use Norton's Champagne sticky back papers - they go as coarse as 80 and that removes the unflat parts pretty quickly. Good luck.
Tim
#1,170 ·
If you hate William Faulkner...
Hello LJs,
Tonight I wrote a 'stream of consciousness' blog pieces. If you hated reading William Faulkner in school, you will find tonight's post to be painful. It does have an exciting ending. So I really can't say if I am recommending you bother checking it out or not. I guess I leave it up to you to determine your own fate and how you chose to spend the next 2 minutes and 45 seconds.
http://extremelyaverage.com/2010/05/i-think-therefore-i-rant/
Brian
#1,177 ·
Back to Some Woodworking
Hey There Folks,
I mostly goofed around this weekend. So today was fun as I got back into the woodworking. I went to ACME Tools, bought 2 small bits of popular and got to use my Stanley 4 1/2 for something other than making practice shavings. I am pretty fired up.
http://bit.ly/bWQTzY
Brian
#1,182 ·
The Practice Worked
Hello All,
I think this is the best set of Pins I have ever cut. In fact, I am sure of it, as I haven't cut that many. Are they perfect? No, but as long as I keep improving, and having fun, it is all good. I even took a photo of one of the set of pins, before I finished cleaning it up, at a point where I would have probably thought I was done before. Now I know I can do better, so I keep working. I love this stuff.
http://bit.ly/bIy4HK
Brian
#1,186 ·
Brian; The first thing you need to do to your new found wood is to seal the ends of the logs. Any old latex paint will do. This will help prevent cracking and checking of the logs as they dry. Some of those logs appare to be limbs, and as such may not be stable when sawed into boards. The fibers in the limbs of trees are subject to great bending pressure in their before life. These same pressures are not found in the vertical growth. Never fear ,however, you have done a good thing saving the wood from the fire of damnation. Be proud and have fun.
#1,190 ·
I try to be honest...
Hello LJs,
My blog post is up, it is fair writing, but nothing to do with woodworking today. I try to let the LJ community know when they shouldn't bother. This might be one of those times. I did write a really great blog piece today, just not for my blog. It sort of sapped all my creative juices and left me worn out and sleepy.
I will do better tomorrow.
http://bit.ly/aLVtn6
Brian
