776K views 1.9K replies 162 participants last post by  Ecocandle
#1 ·
New Year...New Hobby
I have been known to take up a hobby or 37. At 42, on the cusp of 43, and well into the 'balding' years, I have decided that, in lieu of a midlife crisis, I would take up woodworking. Don't get me wrong, a new car and a 27 year old with huge, firm, hands would be wonderful; But I can't afford the 27 year old, and I am not into cars that much.
In the summer of 2009, I went to an arts festival in Des Moines. The gentleman, who won best of show, did so with some amazing etched clay bowls. I am not sure why those clay pots inspired me to take up wood working, or if they were the only inspiration, but shortly thereafter I found myself living in the thriving metropolis of Martelle Iowa. I had my first ever basement.
Without a lot of money to buy all that one needs to build furniture, I started with magazines. The first one was called, "Start Woodworking", from the editors of Fine WoodWorking. I read tips on tools, ideas for projects, stories about great woodworkers, and I began to formulate a plan. I would start with a workbench, the workbench on page 24. The editors of the magazine did a good job of designing a project with the beginner in mind. They even provided a DVD with instructions that were really helpful.
The bench took several months to complete, though the plans were designed so that one could complete it is a weekend. I would guess that I spent 5 hours of thinking about building the bench, for every hour of actual working on it. I thought about what I needed to complete each step, but I was always only focused on the next step. The first step was to buy the 2Ă—4s, 4Ă—4s, 3/8" threaded rod, and a miter saw. Not an electric miter saw, a cheap manual one. I could afford it, it would cut, and I didn't at all care about how long it would take to make each cut. I also discovered in the garage and old hack saw that I could use for cutting the threaded rod.
With the wood cut, I decided I wanted to sand my lumber. The next purchase was a small Black and Decker 'Mouse' sander, some 80, 120, 180 grit sandpaper, and a cool looking level that I didn't need but it was shiny and I was powerless to NOT buy it. The next few weeks found me sanding each piece a bit each day. Barely into my first project I was already getting addicted to the process. The feeling of the construction grade lumber in my hand, after it had been sanded, gave me the slightest glimpse into the beauty of working with wood. I thought about how it must be to run my fingers across a piece of glass smooth mahogany or birds eye maple.
The plans required that I route a 3/8 inch groove into the stretchers. Before I read this magazine I didn't even know what a router or a stretcher was. Each new term learned, each skill set explored, opened up the possibilities that developing woodworking skills offers. And each discovery brought the reality home that care needs to be taken to master each aspect of woodworking. So before I could move on to routing I needed to do a bit of research. This is how one turns a 2 day project into a 2 month quest.
I read reviews and comments. There are many good routers to choose from and I decided to go with the Bosch 2.25 hp router with both the plunge base and the fixed base. I bought 3 bits. A 2" Spiral Downcut CL 2BB and a straight 3/8" by Amana Tools, and a 3/8" Up Spiral bit by Freud. I have come to the conclusion that Freud and Amana Tools are the two best out there. Admittedly Amana makes 2 levels of router bits, and I can't speak to their low end line, but the high end bits have been a joy.
With the router in hand, I had all the tools required to build my workbench. Each step was approached with a sense of confusion and fear. The first time I used the router I was filled with trepidation and pizza, as it was after dinner when I gave it a try. I spent close to 40 minutes setting up a guide for my router. Pieces of 2Ă—4 clamped with 2 24" and 2 36" Jet clamps on my make shift workbench, allowed me to position the router to route. I had read that it is best to take several small passes for safety. Since I was already a bit scared that the router would spin wildly out of control and drive itself into my spleen, leaving me bleeding and generally disappointed, I decided that small passes were a good idea.
It worked as advertised. My first 2 passes made a wonderful 3/8" grove in my wood. I was filled with pride and sure that I was well on my way to being one of the greatest woodworkers of the last 700 years. My second board didn't go as well. I had tightened the collet on the router, though apparently not enough and it had slid up slightly. This had produced a slight up ramp for the groove. My ego needed this set back and I retightened it and decided that I was the greatest woodworker in my basement at that moment. This was good enough for me.
The rest of the project required gluing 2 pieces of Âľ " ODF together to form the top, drilling some holes in the 4Ă—4 legs, and attaching the 9" Jet vice. The only difficult part was installing the vice as it didn't come with instructions, but my own insecurity about getting it right, made me take it at a glacial pace. When I flipped the bench back over and put a piece of wood in the vice, I almost wept with joy.
At the end of the quest I learned several things. 1) When marking wood to be cut or drilled, avoid doing it while watching college football. My bench still bears the scars of several errant holes. 2) Drilling holes with a hand drill, so that they are straight, requires a bit of practice. 3) High quality drill bits are much easier to use than really old, worn out, dull, bits. This likely applies to all tools, the better the quality, the better the results. 4) Fostner bits are cool. 5) I love my workbench, with its shiny red Jet 9" vice. 6) The journey before me is perhaps the most exciting one I have undertaken in my lifetime.
#1,802 ·
Henry Wood Ch 36
Hello All,
I appreciate the comments and feedback. Even the mean and nasty ones, like the one I received an hour or so ago on yesterday's post. I don't mind mean and nasty, if the person is also including accurate corrections, which he did. He did ask that I "please quit abusing the English language!" I guess it isn't that nasty, because he did say please. I am not sure if the exclamation point was necessary though. It is hard to say.
But it does seem reasonable to again offer my apologies to anyone who is offended by my frequent spelling and grammar errors. I can't promise that I won't make many more errors, but I am constantly trying to get better. When word press indicates I have spelled something incorrectly, I don't just right click and fix it. I try to figure out the correct spelling. Alas, word press can't catch things like using "wondered instead of wandered".
So again, I am sorry for the quality. I hope the story is at least entertaining, warts and all.
http://extremelyaverage.com/2011/01/henry-wood-time-and-again-ch-36-mikes-call/
Sincerely,
Brian
#1,803 ·
For those of us who don't have the patience to deal with 36 chapters of Henry Wood, perhaps you could write a short story to help you and us discern whether you really are a fiction writer. Maybe something akin to Hemingway's, "A Clean, Well-Lighted Place"?
http://www.mrbauld.com/hemclean.html
The main difference I think would be the amount of forethought required and attention to detail. Like carving dove-tails was for you, maybe it would be a nice exercise? I think it is unfair to expect yourself to be able to produce quality writing on a day-to-day basis. Wouldn't it be nice to produce something meaningful for all of the time you're investing? I would be willing to volunteer my effort as a critic, if you would like thoughtful criticism. I think excellence comes through rewriting and rewriting. The idea of having numerous spelling errors ought to be a silly notion.
Bill
#1,810 ·
#1,814 ·
I am reading a really good book...
Hello All,
Spike Carlsen, 'A Splintered Hisotry of Wood', is a delight. I am only two chapters into the book, but I became so excited about the stories, I had to write the review. I have decided to write the review in parts, because, well, I can.
If you have a mild interest in wood or woodworking, this book will be one of the best you read all year. Or I should say, the first two chapters will be. If you love woodworking, this will send you into a state of giddiness. That isn't even my review. It is here…
http://extremelyaverage.com/2011/01/splintered-history-of-wood-review-pt-1/
Brian
#1,818 ·
Unhappy Tools
Hello All,
As many of you know, I have been spending very little time in the shop of late. Tonight I got back down there and found my tools were very upset with me. I was even bitten by my belt sander. But by the end, we were all friends again.
http://extremelyaverage.com/2011/01/unhappy-tools/
Brian
#1,820 ·
Just an update...
Hello all,
I did some cleaning of the shop tonight. Nothing worth writing about though. I have still been adding chapters to Henry Wood. I just realized that I have been neglecting the LJ folks. I am sorry about that. There are seven or eight more chapters up now. I just posted ch 45, and I think the last one I told you about was 37. If you click on the Henry Wood heading at the top, they are all grouped together. It is pretty close to 50,000 words now, so this one is offically a novel. Thanks to everyone who has been encouraging my writing. It has made it easier to reach my goal.
Brian
#1,825 ·
I have done a terrible job...
Hello All,
I have been writing a lot, but have done a terrible job of updating LJ. I haven't done much on woodworking though, so I haven't been around. The Henry Wood is coming along, in fact, I just posted chapter 64. So that means there are about 19 more chapters, if you haven't been checking my site daily. I believe the last one was 45.
I think most people from LJ who have been reading Henry Wood, do stop in daily, so I haven't felt like clogging up the blog posts with my daily links.
I do appreciate everyone's support and encouragement, as it has made writing fun. The novel is nearly done and when it is, I will do a rewrite and polish it up a bit. I have also decided to rewrite the 1st Henry Wood, add another 18K words, fill it out some, and get move it from novella to novel.
Thanks again for reading my drivel,
Brian
http://ExtremelyAverage.com
#1,826 ·
I don´t go to your site on daily Basis , I thought you was cought up with rewrite ,reorder Henry wood
and busy with other stuff and last night I wondered about if you were sick or something since we didn´t
hear anything from you at all …......19 chapters …yyyeaarks it will take me a week to catch up :-(
well I better make me some exstra strong Coffee then….glad you are alright
take care
Dennis
#1,832 ·
#1,845 ·
Hello Long Lost Friends
Hello LJs,
I have not posted in a long long time. I used to post every night, but eventually my blog was no longer about woodworking, just additional chapters of my Henry Wood Detective novels.
Back in October I got a job which required leaving my home. The long commute really shortened my days and I lost my 'Woodworking Time'. I had only enough time to write every day.
On Monday I went to the Woodsmith store and picked up a couple of magazines and a nice piece of cherry. I intend to make a few more tiny boxes to give away to promote the release of my first novel. 'The Henry Wood Detective Agency' got its start right here on Lumberjocks and now I am about to finish up the 3rd in the series. (All three should be released this summer, with at least the 1st one having a print edition.)
I wanted to thank everyone who encouraged me and followed Henry on his adventures. So Thanks. Tonight I wrote a blog post with some of the details about how Henry Wood came about and where he is now, if anyone is interested.
http://extremelyaverage.com/2011/05/story-of-the-writing-of-henry-wood/
Thanks,
Brian
p.s. I will however keep posting anything with woodworking foibles. :) Monday I start my new tiny boxes!
#1,846 ·
Good to see you back here Brian. I check in each evening at Extremely Average and follow you thare. I like the current story and look forward to seeing all the sub lines come togather. Thank you for your writing. Nils
