61 - 80 of 93 Posts
platform finished...almost there!!!
I am sorry I do not have a lot of time before going to work, so I will not be able to write a whole bunch. I finished the platform today. All that is left is the backrest. I will hopefully have that finished tomorrow, and then all that is left is the pillows, and legs. Here are some pictures of what it looks like so far. sorry this has to be so short, but I am running out of time…if you have any questions, just ask me, otherwise maybe I can post more about it later on - i just wanted to get something posted because I wont have time to do it later tonight. I hope everyone is enjoying and have a great day!
Very interesting. Did you find plans or some procedure, or did you just figure it out from destroying other couches to harvest the springs? I totally understand being able to lay down on the couch. I'm going to miss our couch when we go cruising.
Discussion starter · #63 ·
I figured out how to make the couch just from tearing apart other couches! As far as the sewing and springs though, I went to the library and learned how to do it - but then I kind of did it my own way too! Yes, the laying down part is key - after work, no one wants to take a nap in their bed, they want to plop down on the sofa and watch some TV…and thats exactly what I plan on doing :) :)
This is a great resource and there's a very good book about traditional upholstering methods: http://www.evenfallstudios.com/woodworks_library/woodworks_library.html.
I accept your info for info deal and I'll have a blog on upholstering a slip seat for you shortly. :)
Discussion starter · #65 ·
Sofa upholstery complete, legs next....
Hey LJ's. So I have the upholstery of the sofa frame complete. The only thing left as far as upholstery, is the seat cushion and pillows!! My next step is making the legs. This is where I need some advice from you guys. I was planning on making some legs that are really big and bulky, probably either black or dark shade of brown (like walnut), but I was wondering what you guys think? I was also thinking about only doing 1 long seat cushion. I kind of like the fact of not having any cracks to lose keys in :) But again, was wondering what you guys think? The pictures are below, and again if you have any questions just let me know and I'd be happy to answer them. Thanks a lot!! My next post will be of the finished sofa under Projects. Thanks for all the support!!
Sorry, I can't figure out a way to make the picture smaller so you can see the whole thing!! Photobucket sucks. Anyways you can click on the picture and it'll take you to the full size pic. Thanks!!
how wide is it again? (re: the cushion)
I think some bulky walnut legs would look amazing on this!
Discussion starter · #67 ·
Tyskkvinna - it is 6' between the arm rests. The arm rests are about 8" each, so the total width is about 88"
Why not build a recessed toekick set back equal all the way around. You know mitered corners and all. Then nothing will get lost under the couch. It is also a high end look as opposed to four feet. Just a thought.
Discussion starter · #69 ·
rhett, that sounds like a good idea! I will definitely consider it!
I've really enjoyed this build well done.
I think large dark/black gloss wood bun feet would look good on this sofa a little like the shape of a curling stone. They would also act as a glide to move the sofa. Regarding the upholstery a single cushion would look ok but you would have to put deep buttons in about every 8" square to stop such a large sheet of material from shifting around on the foam cushion & to retain it's neat appearance, material quickly stretches & would look loose & saggy without some tension. So far you've done a great job I like it
Best to you
Trevor
personally I see this as having some walnut "tubafores" stacked in a reverse pyrimid.. super job my friend..
I agree it need's bulk in the feet but it also need's dimension and texture , stacked 2Ă—4's graduating down would look good to me, and add the added dimension it needs, and at 6 'span a center leg would look good and serve as a extra support .. so a double sided one
mitered corners of course .. or not it would look great either way
l
Looks very good so far. I also vote for bulky dark colour feet. If you are going to make the seat cushion out of foam then just be careful what might happen is when a single person sit on it on the one side the other side might pop up and kinda hang in the air which might not be what you were looking for.
I have also really enjoyed this blog, im super impressed with your fortitude to tackle the upholstering and sewing. I dont think id have the "cajones" to get my Betsy Ross on like that. Kudos to you!
Nicely done!
Although it would be extremely practical to have one large cushion for the reason you mentioned, I was thinking it might be a good idea to have separate ones, in case something gets spilled or anything. That way, you could update a cushion without having to redo the whole thing. Maybe that's not a concern, though!
I do like the cleanness that a single cushion would bring to the look of the sofa.
Super work on this; I've enjoyed following your blog.
I worked for a re-upholster for a while in collage, so I know how much work you are putting in to this.
As for feet I also like the toe kick, it could make the sofa appear to float. but if you do feet go big and dark.
As for the cushion,it would depend on how clean you want the look and how many people you think will be sitting on it regularly. i.e if it is 3 people then some one will always need to sit on the crack of two cushions.
how much did the total cost of the project run? because i was thinking it was cheaper to just make my own
Discussion starter · #79 ·
chris i think the total cost for me was a little under $300 and its a huge couch!! Most of the cost comes from the fabric and cushions. I had all the wood already, and i actually salvaged the springs from old/thrown away couches - so that was all "free." I would say a sofa this size, etc would go for ATLEAST $500 in a store. But it is a custom sofa, so maybe its worth more - one of a kind.
i guess thats not too bad ill have to keep my eye out for some being thrown out. ya i would love to be able to say i made it from scratch. where did u find the jute ties and the straps?
61 - 80 of 93 Posts
