24K views 6 replies 7 participants last post by  xeddog
#1 · (Edited by Moderator)
I have recently heard mention of CA glue accelerator that you can make yourself but no one seems to know how. Rumor is it uses Acetone in the mix. Does anyone out there have insight? a recipe?
Oh, and btw, I use a liquid that spritzes, not an aerosol spray. Costs about $4.95 for a 2 oz bottle.
#5 ·
Any strong base with excess hydroxyl group will help catalyze the Cyanoacrylate reaction.
One DIY formula is one teaspoon sodium bicarbonate (baking soda) dissolved in 1/4-1/2 cup water. If your water has high mineral content and high pH, water alone works too.
Would not recommend sodium bicarbonate spray as part of finishing process for turning. Once the water dries you will find white residue in pores that does not turn clear with more CA on top. So, Stick to commercial sprays when finishing as they are usually colorless.
Commercial accelerators use an 1-3% of an simple aromatic amine (like Trimethylaniline) in a solvent (acetone, naphtha , or alcohol). Aromatic amines are expensive to buy in small quantities, and only trained chemistry geeks should attempt to play with them DIY due Health and Safety issues (known cancer causing).
Cheers!
