21 - 35 of 35 Posts
Discussion starter · #21 ·
SketchUp Plans - Miter Saw & Router Mobile Workstation
I had some fun with this one, it still needs a bit of tweaking, need to add some details and adjust some dimensions, but I thought I'd throw it up to share until I have time to go back over it.
I combined a pretty standard style Router cabinet from an issue of Wood magazine, with a Miter Saw cart from Fine Woodworking, and plopped them both onto a mobile base from another issue of Wood. The Miter Saw station has a flip up, extendable wing on the left side, and on the right side the idea is the router fence could simply be brought flush to serve as a fence (if my spacing is correct, then the fence will cover the router bit so you won't even need to lower the bit)
I still need to add details like the hinges, t-track, etc, and the exact sizes will be dependent on the kind of miter saw I end up getting (all the complex models I just grabbed from the 3D warehouse) but I mostly wanted to see if the overall design I had in my head would work out, which I believe it will (Compared to having them seperate it saves about a foot and a half of width, I only have about a 24" x 72" footprint I can store this in, and it came in well under that)
I also wanted to be able to dismount the miter saw, and drop a planer in, and then simply remove the fences so the wing and router table can serve as infeed/outfeed tables, tho a planer is not in my future anytime soon (I don't have easy access to rough lumber so its not as much of a priority as for many people)
The style is also significantly different than the workbench project, I'm debating which I like more, tho its pretty easy to adjust either one once I've settled on a given look (I want everything in the shop to have a common style).
As always comments/criticism/nitpicking/cookies/pictures of hot chicks are welcome, Sketchup file is here anyone that wants to check it out.
edit: I realized that two of the pictures were before I made a minor modification, I added an extended table top to the miter saw station, I realized when the wing folded down it was hitting the support wing, this should fix that. Also I noticed one of the drawers I must have moved in the wrong direction when I "opened" it. I'm just too lazy to change the pics right now lol!
  • Like
Reactions: gennadi.kocko
Man, I'd love to have something like that. I have my miter saw screwed onto the top of an old cooler. Yuk. I bet you're going to be sorry you left holes in the drawer fronts though. I love sweeping up the sawdust at the end of a good day in the shop but I don't like it inside my drawers.
Best,
THATS A GOOD USE OF SPACE. NICE SKETCH UP WORK. I HAVE SEEN THAT BOTTOM PORTION OF THE CART BEFORE. WHAT IS THE BOX FOR, ON THE BOTTOM BETWEEN THE CASTERS?
Discussion starter · #24 ·
Ah logic, my one weakness…maybe the finger holes weren't such a hot idea….meh, easy fix
REDOAK, thats a series of rails to stiffen the base and help distribute the weight…here's what it looks like from underneath…
That is a great idea
Discussion starter · #26 ·
Fixed the link (they keep breaking for some reason, I been testing them right after I post and they work fine…stupid SkyDrive)
And to answer your question Dave, because that would be a logical, reasonable and intelligent course of action. And I would hope by now we've established thats just not how I roll facepalm Ironically as much as I grab from there it never occurred to me to upload my stuff, I'll try that later.
You wouldn't happen to still have the sketchup files would you? Seems the link doesn't work. :(
I too would love to know if you have the sketchup files? This is exactly what I'm looking for. Looks great!
Are there detail plans of this with measurements for each piece?
The sketchup up link isn't working. Is there another link for it?
Was an updated Sketchup file ever reloaded on here? It's a great project that I'd love to create…just not from scratch.
One suggestion might be to swap sides for the router and the chop saw, my offcuts are on the right, and are often not all that long. It might reduce the number of times you need to lift the hinged table.
Of course, you want to feed the router right to left and perhaps the chop saw would be in the way. Just a thought.
Отлично!! Столешницу фрезера надо сделать быстросьёмной и заменять на более подходящую для пилы
Jeison,
That link seems to not work. Would it be possible to email me the file for building it? It's exactly what I have Ben looking for!
Robert.m.bittner@gmail.com
Discussion starter · #35 ·
Sorry all, but all my old files were online at MS Skydrive, and got wiped out when microsoft "migrated" everything to their newer versions, and any copies I had were several computers ago :(
21 - 35 of 35 Posts
