Help with Walnut/Varathane finish
999 views 3 replies 3 participants last post by  EarlS
#1 · (Edited by Moderator)
I've been building tables and cabinets for quite some time. My most recent project is a new walnut pantry for my wife - I've got an issue that I have not encountered before - any help appreciated.
Solid walnut drawer fronts and doors - "natural" Minwax stain; 3 coats of semi-gloss, water based Varathane.
Some canola oil (dirty fingers after making popcorn) got on the finish - it somehow worked through the layers of Varathane and created a dark, oily blotch underneath the finish? Couldn't believe it - so, tested on the inside of a drawer front - the canola oil literally soaks through the finish and creates a blotch (overnight).
I'm going to create some test pieces - "natural" vs "Am. Walnut" stain; oil vs water Varathane - to try and recreate and fix. But, if someone has run into this issue before and can tell me what went wrong I'd greatly appreciate it. Thanks - Otto.
#2 ·
Did it just discolor the Varathane or actually get all the way through to the wood? I suspect that it has just discolored the finish so in your test, you can try just scraping the Varathane off to see if that is the case.
#3 ·
Lazyman - nope - it soaked through the varathane and discolored the wood. I think if I had used a stain like "American Walnut", instead of just "Natural", the discoloration would be hardly visible. I built up a sample board - some "Natural", some "American Walnut", 2 types of water based urethane, and 1 type of oil based urethane. It's in the final drying stage - I'm going to test it tomorrow morning - in the meantime, I'm stripping/sanding to see if I can sand the blotch out. If not, I'm going to see if a stain will 'hide' it - failing that, I'll be rebuilding the doors and drawer fronts. Very frustrating - this is the first time I've worked with walnut - most of my previous projects have been oak and I've never had a problem with water based urethane before.
#4 ·
I've never been impressed with the water-based poly. I've not had any problems with oily fingers making stains on the top of the 3 computer desks (walnut tops), and the laundry counter top (maple) that are finished with with Seal-A-Coat, followed by a couple coats of Arm-R-Seal and some wax.
You might try some wiping acetone or alcohol on the sanded wood to remove any oil residue that might still be soaked in the wood fibers.
