221 - 240 of 320 Posts
Discussion starter · #221 ·
Cutlist and Layout from Sketchup
If you're a fan of Sketchup for creating woodworking models, then the next obvious step is to use Sketchup to help you create cutlists and layouts. Sketchup plugin Cutlist 4.1 does just that. CutList 4.1 sketchup plugin helps you determine how much of each material you need to produce your design, taking into account nominal sized lumber with allowances for finishing to final size. Then it goes one further and lays out all of the pieces on boards or sheet good sizes of your choosing. Then you should be all set to head for the lumber yard to get all of the materials that you will need with no return trips.
CutList 4.1 was beta tested by our very own Lumberjocks and is now ready for download.
It's being released exclusively to Lumberjocks first. You can download v4.1.10 here . This is a completely free plugin. This plugin has been around since about 2005 but continues to be maintained and enhanced. It's got the look and feel of old Woodsmith magazine cutlists and layouts. A very early version v3.3 was reviewed in the Fine Woodworking blog 'Design.Click.Build.' by Dave Richards and a later follow up.
Note that there is now a forum on Lumberjocks for further discussion.
Cutlist 4.1 has been tested with both Skletchup 7, Sketchup 8, SU2013 and SU2014 on both Macs and on Windows PCs.
Installing. There are now 3 ways to install this.
Method 1 (easiest) Get and install it from Sketchup Extension Warehouse
  • Start up Sketchup
  • from Sketchup choose: Window->Extension Warehouse
  • Search for and select 'CutList'
  • click on install ( big red bar on top right)
Method 2 (easy) Download and install it using the Sketchup extension installer
A relative foolproof way to install is now available with the latest versions (from v4.1.6 and up).
  • Download it from link above
  • Start up Sketchup
  • from Sketchup choose: Window->Preferences
  • click on 'Extensions'
  • click on 'Install Extension', hen navigate to and select the .rbz file you just downloaded
Method 3 (if all else fails) This is a two step process and more error prone
  • The file is a .rbz (a zipped ruby source) file. Extract the entire contents into your sketchup plugin directory not just the startup ruby script (srcutlist.rb). There is also a folder called srcutlistui which contains everything else it needs to work properly. The exact locations of the directories required for Sketchup plugins for Windows or Mac are found documented further down in the blog.
Running on a Mac. This is functional. Only the html output window for the layout does not work because of issues with the Safari browser, however, there is a workaround using the SVG export.
Someone in the forum asked a great question which I will repeat here:
Q. What is the point of the cutting diagram?
A. Why indeed would you want a cutting diagram? There are a few reasons:
  1. Regardless of whether or not you have a cutting diagram, eventually you are going to have to cut some wood to get a project built. How many boards do you need to buy? If you go by the board feet measured ( or calculated by something like the cutlist plugin) you're going to find that it falls short. Why? because when you to to cut the pieces out of the board, you'll find that you will inevitable have waste. By having the cutting diagram, you can see how much waste there is going to be and you know how much to get when you to the lumber yard.
  2. You've got a lot of parts to cut and you want your parts to be as accurate as possible before you even do anything else to the pieces. Ideally you want one setup for each size of part, so that you can cut each of the parts which are the same size at the same time. The cutting diagram lets you visualize how parts may be laid out to minimize on the cuts and the number of setups.
  3. Ok, you've decided to build your project out of sustainably harvested plantation teak. It's selling for $50/square foot(!) for 3/4". You might be interested in using those $200 boards as efficiently as possible. A cutting diagram may also be used to minimize waste. Even if you have waste if you could have a larger part left over which you could reuse for another project vs having a lot of offcuts, you've saved yourself some money and you are using the planet's resources efficiently and responsibly.
So, to sum up, it gives you more accurate project requirements, it minimizes setup time and shop time spent cutting the boards while increasing accuracy and finally it helps to use the resources as efficiently as possible.
Finally here are some screen shots in case you still can't quite figure out what it does or why you would want it or can't imagine what it looks like.
Starting up cutlist. Highlight your project and select CutList from the plugin menu. Make sure all of the parts in your project are named and are either a component or a group. ( Nested components or groups are handled ok as well)
The screen that comes up allows you to select your cutlist options from the type of output you want, what you want to have included in your parts list, which parts are solid wood parts, which are sheet goods parts and which are hardware
and the next page allows you to select the layout options. There is a general options section, a tab for board options and a tab for sheet options.
Here is a sample of cutlist output. This is the cutting list in html format. This page can be printed.
If you scroll down, then there is a summary of the board feet and the materials and sheet parts and hardware are broken down to their own lists with their own summaries
If you selected the layout output, then another window will open and place all of the selected parts on boards of your choosing in a layout which minimizes waste.
Sheet parts layout is placed on the sheet sizes you specified.
There's lots more. There is built in help on each option. Just click on the blue ? next to the option.
Feel free to pass along any comments, questions, enhancement requests or bug reports. I'm committed to maintaining the plugin and make it as useful as possible.
Hi Paul,
The SVG file is your 'layout parts' file. It's the only option on a Mac for this file.
I believe Safari 3.1 and greater (ref ) can be used to open and display SVG files. You might try that first before downloading Firefox.
The SVG file is always placed in the same folder as your sketchup model. If you're not sure where that is, then if you run cutlist again, the popup which tells you that it saved the SVG file, tells you exactly where it saved it.
Within the layout view or the cutlist view, if you want to split the parts into 'solids' vs 'sheet goods', this is done by firstly designing your model in such a way that the sheet goods have a material name applied to them which is distinct from the solid parts.
Then, when you add this name (or a part of the name which would uniquely match the material name) to the 'sheet part words' on the front of the menu ( or use the defaults that come with the plugin), then the plugin will know to select these parts and treat them as a sheet good. Then they will be split in the cutlist and be layed out using the sheet goods criteria.
For example, if you applied a material name to all your sheet good pieces called 'maple plywood' and the word 'plywood' is included in the menu box called 'Sheet Material Words', then all parts which have plywood in their material will be recognized as a sheet good in the rest of the plugin.
Hope this helps!
  • Start up Sketchup
  • Start up Sketchup
Thanks Dave and Steve, between the 2 reply's I was able to find the files. Lets see if you can answer this question. I've just noticed the "grain" in the material I applied to my model seems to be running in the wrong direction(across a board and not along the length of it), is this correctable? Also is there a way of changing the default for the font size when using the dimension tool? Or is it necessary to change each and everyone when adding dimensions?
Paul
  • Start up Sketchup
  • Start up Sketchup
Oh my - I was saying to a friend the other day that all i lacked in sketchup was the ability to output a cutlist - and here it is. Completely gorgeous. Like a big plate of gorgeous with hot gorgeous sauce poured all over it and covered in gorgeous sprinkles. And free!!!!!!! paypal donation on its way - will watch with baited breath for a kerf version but in the meantime I need to go and lay down in a darkened room for a while to recover from the joy! :)
  • Start up Sketchup
  • Start up Sketchup
Hey Dave - just about back to normal (ish). Been very busy , been very well. Glad to see your still out and about as Mr Sketchup wiz.
Discussion starter · #225 ·
  • Start up Sketchup
  • Start up Sketchup
Ian,
Thanks so much for your comments and your encouragement. Welcome to Lumberjocks and thanks kindly for the donation. Adding support for kerfs is in the works and you'll be the first to get a copy.
Phew, I hoped you recovered!
  • Start up Sketchup
  • Start up Sketchup
Hello LumberJocks,
I've just installed the cut-list plug in on my mac. It seems to be all working correctly, except that the window that is supposed to open with the cut list diagram is just blank.
Does that sound like a mac issue, or am I just being an idiot.
I hope it's the latter.
Cheers
Simon
  • Start up Sketchup
  • Start up Sketchup
Hi Dave.
Thanks for that. That's got me a little further - the SVG files are at least giving me some sort of layout diagram, but now I don't seem to be able to get it to show me a layout on a 4×8 ft sheet …?
  • Start up Sketchup
  • Start up Sketchup
Ah - that was all fine, but I hadn't named the components correctly. Now it's recognizing what needs to come from sheets. Great stuff. Thanks Dave
  • Start up Sketchup
  • Start up Sketchup
Wow! Just discovered Sketchup a couple of weeks ago and have been loving it. But it got even better today when I found Cutlist! This is great!
My only problem is that the project I modeled in Sketchup is based on 2×2's, which is not an option in the board selections. I did see the workaround for this posted above, so I'll try that, but I wanted to put in another request for customizable sizes on boards and sheet goods. Sounds like it was being considered for the next version, so…PLEASE!
Thanks for such a great plugin!
Discussion starter · #230 ·
  • Start up Sketchup
  • Start up Sketchup
Hi jcsom,
Your best bet is to customize your copy of the plugin for now. Customizable wood for layout is in the works but as a first step, it would still only be a single selection. ie: 1 can allow 2Ă—2 to be specified but everything selected would be layed out on this material.
The ultimate is to enter all of the pieces of wood you have to work with and to have it lay out on what you have but that's a step up in complexity which would be fun to try to do but I can't guarantee that it'll be anytime soon.
In the short term, I can add 2Ă—2 into the current mix of selectable options. Let me know if you need a hand replacing one of the current selections with 2Ă—2 - it should be pretty straight forward.
In any case, your request has been noted!
  • Start up Sketchup
  • Start up Sketchup
Steve,
Thanks for the offer of help, but I succeeded in customizing it for 2X2s - worked perfectly!
Yeah, being able to enter multiple custom and/or standard sizes would be awesome! I realize that would be a more complex addition, though (v. 5.0???). For now, just being able to customize for a single size without having to go into the code to do it would be nice.
Thanks again for making such a useful plugin available!
  • Start up Sketchup
  • Start up Sketchup
Is there any way to assign a material type (type of wood such as spruce) to a component and have cutlist recognize it without having to apply a sketchup material to the component. Did that make sense?
Many drawings I do I don't bother with assigning sketchup materials. For example, I draw a 2Ă—4 that I want to show up as spruce in cutlist's output. Do I have to apply a sketchup material called spruce to the component (2Ă—4) to make this happen or is there a different way.
Thanks very much for all your affort that has gone into this plugin Steve! It is an excellent tool.
  • Start up Sketchup
  • Start up Sketchup
I was hoping to do it without assigning any materials but I understand what you're suggesting too. Much of the material I use is birch ply and poplar. I could actually make the default material one of these. Most of my work is paint grade builtins and closets so I typically don't apply wood grain materials. I was just looking at other ideas how to accomodate this. One possibility could be through the use of component attributes although I think they are only in Sketchup Pro which would cut out a lot of users.
  • Start up Sketchup
  • Start up Sketchup
Your idea of changing the material of selected components would work great actually. I'll do some searching too.
  • Start up Sketchup
  • Start up Sketchup
Perfect - will do so.
  • Start up Sketchup
  • Start up Sketchup
Dave - thanks for the material change plugin. It works great. I've created several "blank" materials that I've named after common materials that I use (Maple ply, Poplar, Hard maple, etc.) My process now is to create a drawing as I normally would which does not include assigning any materials. After the drawing is complete I select all components of the same material and use the global material change to assign the appropriate "blank" material. Now the cutlist csv contains the proper material name. Saves me some time.
thanks for your help.
brad
  • Start up Sketchup
  • Start up Sketchup
Hey Dave, could you post the name of that materials plugin?
  • Start up Sketchup
  • Start up Sketchup
Hey Steve,
First let me say this is a great plugin and I'm glad I found it!
I think I found a bug. I have a fairly simple project of a desk for my wife. When I try to generate a cutlist for the entire project, the cutting diagram for sheets does not correctly display the last sheet. When I select the layer with sheet components only and run the plugin, it creates the cutting diagram fine.
Also on the layout optimization. Is it me or does the plugin optimize layouts for crosscuts? Would it be hard to add support for optimizing sheet goods layout for ripping. I sold my pickup so I now have to have the store rip panels for transport.
  • Start up Sketchup
  • Start up Sketchup
Thanks Dave,
Doh! I missed that. =/
Discussion starter · #240 ·
  • Start up Sketchup
  • Start up Sketchup
Hi BassPlayer,
Welcome to Lumberjocks!
It could be that you've hit the limit or it could be a bug as you suggest. The html window output for layout has been particularly troublesome in ways that I have no control over when the project gets to a certain size(see footnote 1), which is why the svg output was provided as an option. It picks up where the window output falls off.
There is a 'board' limit, but this was done mainly to try to minimize reaching the window limitations. As I recall, though, I set this fairly high, so most likely you will come to the windows limits first.
(footnote 1) unfortunately this size is not really quantifiable as it depends on your project.
I will contact you offline. If you are willing to share you sketchup project files, I can see if I can get to the root of it. I'm in the process of updating the plugin, so this is a good time to make any changes if there is an issue.
As for layout favoring one type of cut over another on sheets, this is an interesting point. The short answer is that there was no intention for that but it may appear that way or it may come out that way and there is no real option now to try to optimize towards crosscuts or rip cuts, but it's an interesting problem.
The lengthier answer: While no intention was made to favor one or the other, I do have to make an assumption about part orientation since Sketchup has no representation of the grain of a solid (not even the application of a material imparts this attribute since the material itself is just an image on the surface). So it goes like this.:The grain direction is assumed to be in the direction of greatest length.This is true for the boards and for the sheet goods. Parts are placed in the same orientation as the material. That's part 1 of the answer.
Part 2 has to do with the algorithm used to place parts.I won't bore you with the details (it's in the ruby code if you really want to know ) but same-sized parts do end up being laid across the board looking like it favors the crosscut but only because it is more efficient this way but not necessarily easier to cut the pieces out.
It's an interesting enough point, that I might have a think about an option which might favor ease of cutting parts vs optimization of the board. It just might show up as one of those crazy experimental options in the next version!
This plugin is fascinating to me in that I am trying to codify intelligent decisions which we make as woodworkers practically without thinking. Experience can guide us on layout but what is the process in a person's mind when he/she makes those decisions? The computers only advantage is that it can try many different combinations. (Sorry I am getting all geeky now thinking about this interesting problem …)
