I purchased a leecraft ZCI for my Unisaw. I followed the instructions that came with it to adjust the set screws to get it to fit tightly in the opening, then clamped a 2×4 over it and slowly raised the blade. Now I have zero clearance around the blade, but there is considerable "blade noise" now, which I assume is caused by the sides of the teeth just barely hitting the insert. I searched and found some other posts at FWW saying that this is normal and will eventually go away, but the amount of noise I'm getting makes me think that this can't be normal. I'm not sure what could be "defective" about an insert, so I'm not sure where to go from here. I could file the sides of the kerf in the insert, but feel that doing so would defeat the point of having a ZCI. Any suggestions?
