Workbench height
12K views 44 replies 28 participants last post by  ClintSearl
#1 · (Edited by Moderator)
As a beginner I recognise that I need to build the best workbench I can afford, taking into account my low skill level. Planning is essential and that's what I'm doing now, by reading all the stuff on the site and with a couple of books I have. One thing is puzzling me, the height of the bench seems to be a critical factor and I would like to build my bench the same height as my table saw (34") for outfeed. But I'm a bit of a shortarse, I have to stand on a box to scratch my head. Is there a formula or guide to bench height:user height:comfort? I'd be grateful for any advice or observations.
#28 ·
Why not make a bench with adjustable height legs. I seem to recall plans for a bench like that in Shopnotes. I will try and find the issue.
#29 ·
I just built a new bench that is 42" tall. It's going to take some getting used to. I'm planning to put a "shelf" table top under the main top so it can be an outfeed table as well, on a lower surface.
I'm 6'2"ish and my back was killing me bending over to do stuff. I found myself loving using my router table because I didn't have to bend over and its top is 48".
The main problem in building a first bench is that you don't have a bench to help, so it's frustrating (I just moved my shop to my detached garage, and my basement bench I built into the wall, so I left it there).
Good luck. And keep in mind there's a lot of overly complex plans out there, but your first bench doesn't have to be so complex, especially if your toolset is limited.
I also strongly encourage you to check your lighting situation and deal with that early on. I just installed 14 track lights in my new shop and I wonder what took me so long to do it. Previously I had 4 clamp lights and a lot of shadows. In my old shop, I put in 9 recessed can lights.
#31 · (Edited by Moderator)
I will bow to your professional experience on this subject Steve, I'm sure you know what you are talking about, but I have read the elbow height rule in some older woodworking books. Elbow height is pretty darn close to waist height, if not exactly the same. When you are doing some planing it is an advantage to have your right forearm (if you're right-handed) more or less parallel with the bench top and your back relatively straight to prevent strain and to optimize leverage/strength use.
#32 ·
I have seen a lot of personal opinions about beanch height shared on this thread and I am not going say that any one is wrong because their not. your work bench should be a height that is comfortable to you as an individual. Why because it's your work bench and you have to work on and live with it so build what your comfortable with. That may mean experimenting with differant heights until you find the height that is right for you. I have also, including myself have read different rules of thumb which do hold some truth about heights that fit your body and all are valid in that they use your body as a referance to a good working height. Now the first cabinet shop I walked into as a young cabinet maker I heard all these rules and more about what I should do. I walk into room full of as@holes and got a different opinions for every question and over the years it's still true. So my suggestion to any one who asks is to take all this information and there is a lot of it and experiment until you find what's right for you because there are no hard and fast rules to this just good guide lines. Which is a good start. So with all that said, and I don't want to ruffle any feathers around here (I probably will) but I read Chris Schwartz quoated here as to writing his rule at palm height. I don't remember reading that, so I went and blew the dust off my copy of Workbenches from Design & Theory to Construction & Use and this is what I found. Pages 33, 34 is full of good advice. When he wrote the rule that works for him, he stated "Of course everyone wants to know where to start. They want a ballpark idea. So here it is. Stand up straight and drop your arms against your sides in a relaxed manner. Measure from the floor to the place where your pinky finger joins your hand. That has been the sweet spot for me. It might not be right for you." That is page 34 paragraph four. So there it is that is not a hard and fast rule just a guide line. Good luck to all and hope you find this helpful. (now I need to check my spelling)
#34 · (Edited by Moderator)
There are a couple of considerations. First is the type of work you do. FWW had an article a few years ago on this subject and concluded there were three different heights possible
- palm height = power position for planing and hand tool work
- navel height = control position for portable power tools such as routers
- chest height = detail position
A friend of mine has a "standard height" workbench but has gotten into a lot of inlay work and has a booster bench that raises it to chest height and that booster pretty much remains on the bench.
The other issue is how you are proportioned. I'm 6'5" but have a long torso. My 5'10"-ish wife has the same pants inseam as I do. So half your height +2 would not work for us.d Waist, likewise, is ill-defined. Because of my torso, my belt line (waist?) is pretty low. But some "high pockets" (old geezers who wear their pants "over the hump") might consider their waists much higher.
When I started, I inherited a bench at an apartment that we rented. It was a number of years later when I got more serious and built my own bench to spec, that I discovered having such a low bench was the cause of my backaches after an afternoon in the shop.
#36 ·
Whatever the choosen height,
if you handplane a tick slab with a wooden plane while wearing slippers with a thin sole
or if on the same bench, you handplane a thin board with a metal plane while wearing heavy safety shoes, there might be a difference of a few inches.
What about using a grating to be higher when needed?
#37 ·
I obviously hit on a subject that brings out views, opinions and passions! The range of heights recommended or suggested is vast, this is all great stuff though. I've been thinking a lot about building my first bench and I now realise that this one won't be my last. I'm definitely a power tools woodworker right now, the hand tool skills may come with practice but for now the dual purpose of bench with outfeed height for my table saw (34") is what I'm gonna go with. Thanks everyone for such a positive response to my first forum post.
#38 ·
I know this is a old topic, but for anyone interested I thought I would post my 2 cents worth. Fact is no matter your height, we are not built the same. I have been building a bunch of mobile stands of late for various tools, and in comparison to store bought tools etc and my little harbor freight workbench I bought, I think stuff is designed for dwarves. I'm only 5'11" but I find if I have to spend much time at all hunched over something at my age that my back starts to ache. Tonight I spent over a hour working with my Ridgid oscillating sander smoothing some boards and when I was done was just as good when I started. I believe it's cause the stand is set up so the table is at a perfect magic 42" in height. Now the trick is everyone's magic number may be different, but it is easy to find I believe. Eyesight of course could change things, but given normal eyesight, have someone measure from the ground to the bottom of your elbow with your arms at a 90 degree angle from your body. No bending, your arms rest comfy on whatever tool. Take tool height and subtract that along with coasters etc and you have the stand height. I have a post about my HF workbench on here in another thread, and even though it is not up to 42" it is so much more comfy after I jacked it up 4" with a mobile stand. I may build some risers for it soon to bring it to that spec.
#39 ·
Hi Whiskers. I think the reason that proper bench height is so contentious is because benches were originally used mostly for planing and chiseling. The idea was to get your weight placed over the plane or chisel so you could use your whole body instead of tiring out your arms and shoulders. That height of course doesn't work for power tools since they do all the work. This has resulted in compromise to accommodate both hand and power tools. I think the norm is about 34 to 36 inches nowadays, but personally I like it higher than that, and I am also 5'11".
I read an amusing article by a 19th century writer who visited an English cabinet makers shop where the benches seemed unusually low. He found that this was because the floors were never swept and the shavings were compacted to a height of about 8". My first thought was that these were some pretty lazy woodworkers, but then I remembered that shops in those days weren't insulated and probably not well heated, so those shavings probably kept the floor insulated and had some 'give' which would make it a lot more comfortable to work on. I'm not sure how their backs were after a days work though!
#41 · (Edited by Moderator)
I have a woodworker friend who made a comfortable living at it and is now retired and building his workbench.
The basic part is 4 heavy acme threads about 18" long and heavy acme nuts. His bench will be capable of at
least 12" of adustment. There will be gears, chain and a small reversing DC motor to do the work. He has
some wonderful hand and power tools and plans to play with all of them. He has worked enough to be able
to play now and enjoy it. The height of a work bench is as bad as trying to decide which gun is the best one,
great for a fun discussion over a beer or two, but everyone will go their own way. Hope you all have fun in
the shop. No I do not have a permanent workbench yet, but I might get around to building it someday.
Manana.
#45 · (Edited by Moderator)
Forget about bench height. Woodworking is about making stuff, not about furnishing a theoretical shop. Get started by making something, and using whatever work surface is handy to complete the project. The shop will evolve (along with how high the bench should be).
