thanks for the lengthy reply. So as a simple answer, either wood to wood or metal to metal with the same glueline thickness, the epoxy with metal particles will produce a stronger bond? - Jimothy
Hmm,
Mismatch in terminology confuses me?
Whole idea to adhesive bonding is to use proper adhesive for material and joint.
Wood to wood, can use many different adhesives.
Epoxy adds no advantage to a wood to wood bond, compared to other adhesives. Regardless if filled with metal or not. Wood is weak. Even a lowest strength PVA (white glue) is stronger than the wood. So you don't need epoxy for wood gluing, unless you need epoxy for a different reason.
PVA adhesives (white/yellow wood glue) are single part adhesive intended for porous surfaces. They have more than enough strength to create a bond stronger than wood, as long as bond line is uniform and relatively small. There are simple PVA adhesives that are reversible with water, and modern water resistant blends that include secondary cure mechanism to reduce water permeation. All of these are stronger than wood.
PVA will not fill large gaps, as it is weak when used as a polymer filler. But when you fill the PVA with wood dust, it becomes a usable and strong putty.
Epoxy adhesives have higher bond strength than PVA, and do not depend on porous surfaces to remove water and enable hardening or curing. They are able to bond to many different base materials, and are great for bonding dissimilar materials. They are also more expensive (4x+ in volume) than PVA, and rarely used to bond wood to wood.
Epoxy is sometimes preferred in wood bonding, when wood is very dense and oily; which reduces penetration of PVA adhesive. They are also popular by non-wood working types for repairing cracked items with larger bond line or where previous adhesive can not be adequately cleaned from surfaces to exposed wood pores.
Use of metal filled epoxy for wood is considered a waste of money. The improved properties created by metal have zero benefit when bonding a weak substrate like wood. Metal filled epoxies only help with dealing with stronger metal substrates.
Cheers!
