Weights for Shop - Railroad Track Steel
1 reading
4.7K views 29 replies 25 participants last post by  ibewjon
#1 · (Edited by Moderator)
Every once in a while you need to hold down large pieces while glue dries or other reasons, and maybe you start piling on whatever you have on hand that has any heft. I've heard that small lengths of railroad track steel make excellent shop weights. I have no idea where to get any legally though, and I live in a major city.
So, can anyone suggest where I can buy a few chunks of railroad track steel?
Or, can anyone suggest other cost-effective alternatives? I'd like to avoid cinder blocks.
Thanks!
#2 ·
Just take a small section out of any old track, nobody will notice it gone ;-)
I have a railroad behind the house and found a 8" piece when they were replacing the main track once and kept it as a anvil. It is super heavy. Most rails are set in quater mile sections these days so the only place the are likely to be found is near road crossings and switches. Even then if found I would have no idea how I would cut to size.
#3 · (Edited by Moderator)
several years ago, I came across a few hundred pounds of ballast lead from a sailboat.
I melted a lot of it down and put it in soup cans with an eye bolt for easy handling.
each can weighs about 22 pounds.
I also have a bucket full of 3 and 5 pound lead scuba diving weights.
so the lead may be more readily available in your area than train track.
at my local scrap yard, lead sells for $1.00 a pound.
also, my local family owned battery shop sells it for the same price.
check with your local tire shops to see if they sell scrap wheel weights.
#4 · (Edited by Moderator)
You may have better luck finding Elevator Counterweights a couple of the shops in buildings where I do business have them left over from reno projects, but they won't give them up, no matter how many meals I've offered. I've wanted one for the weight use but also for an anvil when needed. I have a bunch of plate weights I found next to a dumpster and 2 1.5 gallon buckets filled with concrete that I use when they are easier than clamps.
#5 ·
A good lead source is your local service station and auto shop. They remove wheel balance weights when re-balancing a tire and usually throw these old lead weights in a scrap bin. Just ask.
#6 ·
I found track at the local scrap yard.
I made a small anvil out of one piece. Cut the other one in half for weights.
Also picked up several barbell pieces at the local Habitat Restore. They make good weights to use in the shop also
#10 ·
There's usually track on eBay but you're gonna pay for it…
They often replace sections of track around here and usually throw the old track on the the side and leave it. If you see them doing maintenance, swing by the area after they're done and see if there's anything in the weeds. Be careful to observe any posted signs though concerning trespassing. Most railroads take liability issues very seriously.
In lieu of finding some track, go to a local scrap yard and just look around for big hunks of whatever. Also watch the free section of Craigslist in your area. There are often weight benches listed.
#12 · (Edited by Moderator)
Personally I just use the round barbell weights. Easily found at walmart or sports stores.
You could try to find some counterweights used in theaters for the ropes fly systems. They're rectangular and flat, a good shape for glue ups. You could try to find some at a local school or theater, they often have spares that get used as door stops. I'm not sure where to buy new, but if you have a theater supply shop locally, they could probably order through a catalog for you.
**I just looked at Ebay for "Railroad Track" and there is way more results than I expected.
#23 ·
Well if you lived in SE Washington I would say stop by, I have about an eight foot long piece of it I'd give you. Don't know how you would cut it into usable pieces but ,,,, I used it to drag it behind my tractor to level ground…
