Stickley Quadralinear Leg
4.8K views 10 replies 9 participants last post by  Northwest29
#1 ·
From a Robert W Lang's More Shop Drawings For Craftsman Furniture, there is a section on how Stickley used the Quadralinear leg to achieve quartersawn on all four sides. I used it on my chair. The article states when stacking quartersawn on two sides and laminating the other two sides there was discoloring in the wood from staining or fuming. Stickley could easily machine this joint in his factory. Lang shows a process using the table saw. I followed the process on my Morris Chair and ottoman. Of course I had to divert from part of Lang's process. The legs pieces are 2.5" wide by 1" thick. I made mine 1 1/16" thick. I first cut a 1/4" x 1/4" groove in their prospective locations.
Next unlike Lang's, I held the piece on a jig to cut the 45 degree cuts. This is where the extra 1/16 comes in. On my test cuts at 1" thick there was some tear out on the edge. The extra material allows for planning down to square.
Once the cuts are precisely made there should be no gaps in the joints.
The joint was easy enough to make and it made a natural mortise that I used to attach the arm to the chair.
#2 ·
Nicely done and illustrated Dan, thanks.
#3 ·
Great post and thanks for sharing!
Jon
#4 ·
Good information and an excellent fit!
#5 ·
Hi Dan …..This is Joe (wooded) I'm still getting your posts via email. This one is great with nice demo. Have started turning again a will be chiming in. Have missed the jocks a lot.
#6 ·
That is a slick trick that I'll have to try to remember when I start making the various pieces of craftsman furniture for the house.
#7 ·
Wow, that's impressive to do it the old school way. Looks like your angles came out spot-on.
I've made lots of posts like that, but always use a locking miter bit. Just one router bit with one setup makes it pretty easy to handle. Your method looks like there's a few more steps, but the results are impressive.
#8 ·
Awesome Dan. Thanks for posting this. I've seen that type of leg and a sketch or two of how it's done but your tutorial with pictures really brings it all together. Love the legs and love the chair!
#9 ·
I'm a little confused about the picture of the dial indicator on the right side of the fence though. Is that just being used as a micro-adjust or some other purpose?
#10 ·
I m a little confused about the picture of the dial indicator on the right side of the fence though. Is that just being used as a micro-adjust or some other purpose?
- HokieKen
Kenny, yes that is my micro adjustment, ugly as it is. My fence is pretty close but if I need something dead on I can get it. It was very helpful cutting grooves and angles for the legs.
#11 ·
A locking miter bit could also be used. HTH
