The static electricity is collecting on the metal part of your hose, in this case, the hose clamp. Okay, that’s what you said. The easiest way to not get shocked is to ground the metal part you’re touching, before you touch it. I would, and have, used a piece of solid copper wire, like from some 12 gauge Romex, slide the bare end under the the hose clamp and secure. Wrap part of the wire with electrical tape, I use shrink tubing, so you can grab the wire, and touch the wire to a grounded surface before handling the hose clamp. I would also suggest that you ground the metal case of your tools when you can. I use drag chains or cables on my mobile tools (which is all of them). I only suggest this because you imply this end gets moved around, and, it’s pretty hard, at least I’ve found, to eliminate the static charge on a dust collector hose that is moved from one tool to another.
