Stanley Screw Sizes Reference
There is no way in this site to post a table or a viewable reference file, so this is the best I can do. Stanley planes are notorious for non standard thread sizes so this is an attempt to catalogue them by plane number.
Order of data:
Outside thread dia. … TPI … Description … Measured dia (optional)
Caveat Emptor
Fractions and decimals are inches. Numbered sizes have the # after the digits.
Formatting doesn't allow me to put the # before the numbered dia.'s.
Anything with [square brackets] is disputed.
Anything with a ? I will fill in if you tell me.
Any plane you have that is not listed, I will put in if you give me measured specs.
Remember, just because it is correctly listed here doesn't mean it is always the case.
Notable Comments
see also DonW's plane notes
Bailey Bench Planes (No 1-8)
12# …. 20 …. Knob rod … 0.2050 to 0.2150
12# …. 20 …. Tote rod … 0.2050 to 0.2150
12# …. 20 …. Frog Attachment screws
9/32 …. 24 …. Depth adj post … 0.281
9/32 …. 24 …. Lever cap bolt
1/4 …. 24…. Frog adj bolt w special slot
7/32 …. 24 …. Frog adj clip screw
5/16 …. 18 …. Cap iron screw
Block Planes (No 9, 15-19, 60-61, 63, 65, 110, 118, 120, 203, 205, 220, etc)
0.276 …. 24 …. Lever cap post
0.275 …. 24 …. Depth adj post
0.228 …. 18 & 20 …. Knob (changed over time)
0.198 …. 28 …. Dual depth screw (No 220, 60 1/2, etc) . . . and . . . 1/4 …. 28
No 10, quarter and half
No 11
0.260 …. 18 …. Round head handle bolts
0.285 …. 24 …. Lever cap bolt
0.209 … 20 … Frog mount screws (very small head)
9/32 …. 24 …. Depth adjusting bolt
5/16 … 18 … "Cap" iron screw (small plate to engage depth yoke)
0.209 … 20 … Toe plate screws
No 12 & 12 1/2
0.308 …. 20 …. Card / lever cap bolt
0.293 …. 18 …. Angle adjusters (2 nuts)
No 13, 20, 113 Circular planes
No 38, 239, ...
No 40 & 40 1/2
12# …. 20 …. Knob post … 0.213
12# …. 20 …. Tote post … 0.213
0.252 …. 18 …. Lever cap screw
No 45 (later)
0.257 …. 20 …. Blade capture bolt
.? …. ? …. Blade capture clip bolt
0.237 …. 28 …. Body rod lock screws
1/4 …. 28 …. Right side depth lock screw … 0.244
0.288 …. 28 …. Right side depth post
1/4 …. 28 …. Slitter/Depth thumbscrew w shoulder … 0.245
1/4 …. 28 …. Blade notch adjuster post … 0.247
1/4 …. 28 …. Sliding section rod lock … 0.247
1/4 …. 28 …. Left side depth thumbscrew … 0.247
8# … 40 …. Nicker screw … 0.162
1/4 …. 28 …. Fence lock thumbscrews … 0.247
0.204 …. 20 …. Captive dual micro-adjust . . . and . . . 1/4 …. 28
12# …. 20 …. Knob post … 0.217
? …. ? …. Cam screw (older pinch style mechanism)
1/4 …. 28 …. Cam screw (Later type 16 w brass pin inside)
0.389 …. N/A …. Rod dia.
0.279 …. N/A …. long depth stop dia.
No 46 (earlier) and 47
12# …. 20 …. Knob … 0.213
0.274 …. 28 …. Rods
0.255 …. 28 …. Blade capture
1/4 …. 28 …. Fence thumb
1/4 …. 28 … Brass depth stop
Slitter mount = Rod
0.194 …. 28 …. Special fence (doesn't match the No 45)
5# ... 40 … Nicker screws
No 48, 49 swing arm tongue and groove
No 50
9/32 …. 28 ….Rods … 0.272
1/4 … 28 …. Wing nut … 0.242
0.173 … 28 …. Depth stop thumbscrews
0.235 … 28 …. Fence thumbscrews
0.206 … N/A …. Depth stop post, no threads
Spokeshaves
No 51 (early)
0.206 …. 20 ….Cap post screw … 0.206
0.137 …. 28 ….Lever cap tightener … 0.137
No 53 (early)
0.211 … 20 … Cap post screw … 0.211
0.168 … 20 … Lever cap tightener … 0.168
No 151
? … ? … Cap post screw
? ….? … Pair depth adjusters
No 153
No 55 Oh boy. (see image at bottom of post)
++Main body++
0.389 … N/A … Rods (61)
1/4 … 28 … Rod screw locks (29) ... 0.243
1/4… 28 … Depth adjuster slotted rod (27) ... 0.246
0.188 … 28 … Captive clip screw for blade lock wingnut (near 29)
0.257 …. 20 … Blade holder thumbnut rod (24)
0.283 … 20 … Rt side fixed depth Adj rod (70,71)
0.255 … 28 … depth rod lock screw (not shown)
1/4 … 28 … Slitter lock screw (76) ... 0.245
? … ? … Nicker screw (85)
++Skate w Left Side Arc++
0.250 … 28 … Skate dual thread depth adjuster (37)
and 0.288 … 20
0.4875 … 26 … Two Barrel posts (32)
1/4 … 28 … Rod lock screws (31) ... 0.244
0.247 … 28 … Depth stop lock screw (?)
++Left Fence++
1/4 … 28 … Two rod lock thumbscrews (58) ... 0.242
0.204 … 28 (lf handed)… Captive microadjust dual screw (?)
and 0.2465 … 20 (rt handed)
0.179 … 28 … Microadjust lock screw (50)
? … ? … Rosewood attachment screws (57)
++Right Fence++
1/4 … 28 … Two rod lock thumbscrews (51) ... 0.242
? … ? … Rosewood attachment screws(52)
++Nosing Attachment++
0.208 … 20 … Depth adjust rod (41)
0.230 … 28 … Depth lock shouldered thumbscrew (43)
1/4 … 28 … Horiz lock shouldered thumbscrew (42?) ... 0.245
++Misc++
0.282 … N/A … Depth stop rod (73)
.? …. ? …. Cam screw (81) (older pinch style mechanism)
1/4 …. 28 …. Cam screw (81) (Later type 16 w brass pin inside)
No 56 & 57 Chute Plane and Board
No 62 Low Angle Jack
No 66 Hand Beader
0.185 … 28 …. Yoke thumbscrew
0.185 … 28 …. Fence thumbscrew w shoulder and washer
No 69 Hand Beader
No 71
12# … 20 … Knobs … 0.2050 to 0.2150
1/4 … 28 … Front foot / Hold down
1/4 … 28 … Height adj
10# … 24 … Fence attach
1/4 … 28 … Depth attach, main body
1/4 … 24 … Depth attach, aux
12# … 24 … Cutter lock screw
No 72 Chamfer Plane
No 75 Bull Nose
... ... Lever cap screw
... ... Body gap bolt
No 78
[1/4 … 24] … Fence mount rod
10# … 24 … Depth thumb screw
1/4 … 18 … Cap screw
? … ? … Fence lock screw
No 79 Side Rabbet
0.1845 … 27 ... Cutter lock thumbscrews, really, 27, not 28 tpi
0.186 … 28 … Two nose mount flathead screws
? ... ? ... Two fence screws
No 80
0.245 … 28 … Plate thumbscrews w hole … 0.245
0.245 … 28 … Pressure thumbscrew, no hole … 0.245
No 90 Bull Nose Rabbet
? ... ? ... Depth bolt
? ... ? ... Body locking screw
No 95 Edge Trimming
No 95 gauge
0.174 … 28 … Special shoulder bolt …0.174
No 98 & 99 Side Rabbet
[12# …. 20] …. Knob rod
[0.1845 … 27] ... Cutter lock thumbscrews, somebody check theirs
? ... ? ... Depth stop screw (on post 1930 models)
Tiny Block Planes (100-101+1/2, 201)
? ... ? ... Lever cap knurled screw
No 140 Skew Block
0.2525 … 18 … Lever cap wheel
0.198 …. 28 …. and … 1/4 …. 28 … Dual adjustment depth screw (same as No220)
10 … 28 … Side plate screws
No 146-148 Match Planes
?... ?... Lever lock thumbscrews
No 180, 181, 182, 190, 191, 192 Rabbets
No 196 Curve Rabbet
? ... ? ... Blade depth rod, captive
? ... ? ... Lever lock thumbscrew
? ... ? ... Lever cap pivot screw
? ... ? ... Fixed depth stop bolt
? ... ? ... Depth rod, captive
? ... ? ... Depth lock wing screw
? ... ? ...Horiz lock wingscrew
? ... ? ... Horizontal fence rod, captive
238/239
279
289
340
387
444
? ... ? ... Blade lock, long
? ... ? ... fence wing nuts
? ... ? ... fence capture. wing bolt, small
9/32 … 28 … fence rods
? ... ? ... Fence locking flathead, small
10 … 28 … chip deflector flathead screws
8 … 32 … Nicker screw
600's Bedrocks follow the same schemes as the regular bench planes (No1-8)
Order of data:
Caveat Emptor
Notable Comments
No 11
No 12 & 12 1/2
No 38, 239, ...
No 40 & 40 1/2
No 45 (later)
0.274 …. 28 …. Rods
Slitter mount = Rod
No 50
Spokeshaves
No 51 (early)
No 53 (early)
No 151
No 153
++Main body++
and 0.288 … 20
++Left Fence++
++Right Fence++
++Misc++
No 66 Hand Beader
No 69 Hand Beader
No 71
No 72 Chamfer Plane
No 75 Bull Nose
No 78
No 79 Side Rabbet
No 80
No 95 Edge Trimming
No 95 gauge
No 140 Skew Block
No 196 Curve Rabbet
238/239
279
289
340
387
444
