Many sources of info on smoothing wood state that sanding should be avoided; use a good smoothing plane and proceed to finish. Me, I get extremely thin shavings from my bench planes, but, if the board is wider than the plane's blade, there will always be tiny ridges remaining. In short, smooth with my bench planes; then a final 220 or-so grit sand.
What is your routine? Do many of you stop at the smoothing plane (no ridges)? If so, what is your technique for avoiding the ridges?
Thanks.
Thanks.
