I have a question about using only the outer blades from my dado stack to make a 3/8" groove. The plans I'm using indicate I only need the outside 2 blades (which total about 1/4") and then flipping and running once more for 3/8". In some dado stacks I've seen, the teeth of the outer blades are pretty far apart; mine are almost like a normal 40T blade but with only two big gaps for the chippers. In everything I've read, when using the chippers, the teeth should be oriented to be in the gullet of the outer blades (or in my case in those big gaps). But if I only need the outer blades, there isn't a setup I can do where the cutters of one blade aren't sitting against the side of the other. Is this safe?
