Im building a router sled 4×7.5ft out of MDF for.my base and linear slide rails guides that are generally used for CNC machines. I've glued/screwed 4 sides to provide a rigid base. Will likely add 4"x1"x48" MDF pieces underneath as well for rigidity. However, I was wondering if I should add these to the base where my piece will sit. I've seen some with just a flat base while others have rails. Any pros or cons to adding rails?
I generally shim my piece to get as flat a surface on the beginning side. My concern would be shimming of I have rails.
Im also wondering on the shimming as I've seen a video where you put in shims, flatten one side, then they say to keep the shims where they are and flatten the 2nd side. To me this doesn't make sense. Any thoughts on this? I'd think that with one flat side you'd want it flat with your base before doing the 2nd side.
