A pleasure to be here guys! I fall somewhere between a DIY and a contractor that focuses on residential & commercial remodels / build outs. Over 20 commercial spaces (cafes / beer gardens / coffee shops) built out, and over 30 sub-4 family homes renovated (ranging from light, to complete gut and rebuild). For the most part, all work was done on the construction site. My tools used tend to be in the Dewalt, Makita, and Bosch range. Have limited experience in a couple of projects which you can call true fine woodwork (using a real shop, Festool machinery, etc)
The wife just picked up a teak mid century modern dining table, designed by John van Koert, from the Profile series, fabricated by Drexel. The table seems like a solid build, and not a veneer finish. Used condition, with the table top surface in need of refinishing. Luckily the chairs are good as is! We noticed two issues that I'd like to tackle: 1, general refinishing of the table top, 2. white rings forming under warm/hot cups, plates etc-which I'm hopeful is attributed to moisture getting trapped in between layers of products over the years.
Being a teak unit, I thought it was simply finished with teak oil, so made the first refinish attempt using (que the laughter) a Makita palm sander, with grits: 80, 120, 220, 400. As the sanding continued, some areas revealed the natural wood, others didn't quite get there (as it later turned out, I hadn't fully taken off the finish, as you could see the scratch marks from the 400 grit hand sanding in the light). I decided to test-finish the unit with Starbrite teak oil, which upon drying confirmed that indeed the table was stained.
Now I'm ready for a round two, and to do it right(ish). Purchased a Bosch ROS (ROS65VC-6), with the Mirka Abranet discs (80, 150, 220), and am ready for action.
A couple of questions on the approach (and please correct any of my assumptions prior stated):
1. Only the top needs refinishing. Thoughts on refinishing all surfaces, or just the top?
2. In either case will need to match a stain-any preferences on stain products?
3. Finishing: Starbrite teak oil seems to be the preferred choice. Prior to it, I had always used Watco, which I now understand is an oil/varnish mix, as opposed to a pure oil base.
4. Any other considerations/items I should take into account?
Thanks guys! Looking forward to finally starting on the woodworking journey.
