Plywood Strength Parallel with Plies
1.3K views 4 replies 5 participants last post by  jerryminer
#1 · (Edited by Moderator)
I have a 3 commercial desktops and would like to make a c-leg style bases for workstations. If I use plywood, I'm thinking about a design like this.
NOTE: I'd radius the inside corners as well to provide a bit of gusseting. Where the front skirt and top attachment pieces join to the plywood, I would drill holes to screw into dowels.
My concern is if the plywood would have the strength to support someone sitting on the open edge of the desk. None of the strength tables showed plywood being used in this capacity - they were all for typical sheathing applications with strength perpendicular to the plies.
Thoughts?
#5 ·
I think your design would probably work. For a definitive answer, there is no substitute for a prototype!
(you could scale it down 2/3 and prototype with 1/4 ply and load-test at little cost)
Let us know what you learn.
