Greetings all!
I'm the new guy on the block and began telling my story Here on my LJ Blog.
I hope I landed in the right forum for this question!
While I have already begun my homework on building a band saw mill, I am hoping to gather better information all in one spot.
There is so much to absorb, and my bookmark button is just about wore out. Not to mention my memory at remembering which ones I want to refer back to at any given point.
What I am hoping is that some of you would like to show off your mills, and toss in anything you would change if you had to go back and build it over again.
I am currently running with a homemade chainsaw mill I put together. While it does perform beautifully I find it back breaking work and have access to far more logs of my choice than I can possibly get through with it.
So a few questions to start with-
What is best gas or electric? I will be setting up in one place and a power source is close at hand, so it's more of a cost/ efficiency question.
What HP is optimal? I am planning for nothing larger than a 36" diameter max.
Best material for wheels? There seems to be a lot of controversy over using car/ motorcycle wheels. Pros and cons?
For blade lubrication, does water alone suffice? This seems to be another controversial point across the internet.
I am not worried about the "convenience" items such as lifts to load the logs as I have access to a decent sized front loader to handle that.
The bottom line, I will be assembling the mill from whatever materials I can scrounge up on a strict budget. College tuition is brutal! Especially when multiplied by 3!
Alright, who wishes to show off their mill?
