121 - 140 of 458 Posts
Hi Mike, and all the rest of the bucket team!
Here are my blog on my version of the plane, I also still need to round the sole, and do the final shaping of the plane:
http://lumberjocks.com/mafe/blog/20803
It's a different style, shorter, and with a block plane iron.
Without you Mike I would never have even started, so I thank you a million.
Best thoughts,
Mads
removed
it realy does make a deasen job ….lol
just kidden you …great job as usual from your side Mike
you hit it spot on with those little rough shaves
compared to what they did in the old days when the work just had to be done
and fast as possiple
and I´m glad to hear and see you made a great plane when the bottomis flat :)
thank´s for sharing it was a pleasure tofollow you thrugh this toturial serie of plane making :)
take care
Dennis
Discussion starter · #137 ·
removed
Thank you guys! I did forget to include installing the wedge pin and making the wedge. I will have to add that to the blog later today.
MADS I guess the next work is the binding lever and the knife. I will of course blog this, but you know a lot more about knife making than I do. My approach will basically be to break the plastic handle off an inexpensive hunting/toll knife (I have several old ones), and glue it between to longish boards and then shape the handle afterward. I intend of course to hollow out a little on the inside of both boards to match the blade and tang profile and epoxy it in. The handle has to be long enough so that it can be held against the body to put maximum leverage on it while cutting the 'lag' or bottom groove. Please let me know if think this approach is ok.
The problem with my book on lagging is that there are no instructions about how to make the tools except for the binding lever which has a design and dimensions. That of course makes it more fun because we have to use our own brains and creativity. the bucket work is well documented though, so don't worry about that.
removed
Hi Mike,
There are many ways of the knife making.
Yours are one of the easy and fine ways, not the Scandinavian one. But good.
I think for maximum strenghts I would choose the traditional Scandinavian where you drill holés close to each other, and then file out to fit the tang. I think also it should have a bolster of you intend to use the liver force, so the knife will not break out the wood…
I will gladly suply you with the knolage, or we can make two again…
I can make a scandinavian traditional, any you make it the way you propose… Yours are the faster, but only possible throughout the strenghts of the epoxy, and after my time line there were no big supply of epoxy in the middleage… LOL.
What do you think my dear Mike?
Best thoughts,
Mads
Discussion starter · #139 ·
removed
Thanks Mads. I'm not too worried about making the tools in the old way, but In my book it shows only a short end of the knife, maybe 3cm sticking out from the handle. I'm guessing a short blade will give better control.
If you drill for the tang you would have a long blade, unless of course, you had a tang with a short blade on it. For others this method would probably a necessitate a lot of grinding. That's the main reason I'm thinking of the glue-up method I mentioned. that way a good part of a longer bladed knife could be buried to leave just the tip.
As for the cut, the book says to first score the cut lines with a sharp knife before using the lag knife. This might prevent crushing the wood fibers.
I'm not sure what you mean about a 'bolster'. In the book it just shows the knife being used like in the drawing and with arms locked against the upper body and the resulting weight used to produce the leverage needed. Does that sound right to you?
Please let me know what your thoughts are on this. I don't mind us doing it differently as it will give the others a choice of methods which adds alternatives and flexibility to suit their personal preferences. I also want you to know how much I appreciate your participation and contribution to this project. I hope you are enjoying it as much as I am. It is fun to do this hands on history study. It is such a shame that so many wonderful woodworking skills and products are, for the most part, unknown to the modern world, especially considering the impact that much of this work has had on our various cultures.
Discussion starter · #140 ·
removed
Jamie Thanks and yes it feels good.
David Thanks for the tip. I'll give it a lot of thought before I start sawing.
Tim Actually the plane blade I showed early on was a scrub plane blade that just happened to be the right radius. I was going to use it for this plane, but I decided I had to show how to grind it and sharpen it, so I took a blade from a cheap no. 4 and used that instead.
