Making an Ancient Wood Bucket: Tools, Materials, and Project Steps
110K views 457 replies 49 participants last post by  stefang
#1 ·
CONTENTS OF THIS BLOG
I am glad to see that there are many others besides myself who are interested in ancient woodworking. In this first blog of the series I will suggest how the group can communicate and function efficiently , timing for completion of the various steps, What materials can be used and alternative methods for those of you who are mainly interested in the finished bucket and/or just don't have the time to make or use the shop made tools.
WHAT IS THE BACKGROUND FOR THIS PROJECT?
The idea and background is laid out in my last blog here http://lumberjocks.com/stefang/blog/20546. Here once again is what we are making.
"Photobucket"
FOR THOSE MAKING THE TOOLS
As mentioned before I hope as many as possible will make their own main tools for this project, but I want to allay any fears about either the tools or the materials. With that in mind alternatives and philosophy are covered below.
Personally, I don't want to be TOO obsessive about using ONLY the ancient type of tools. For example I plan to use my cordless drill for making holes and my Stanley handplane for angling the edges of the stave's and also to round the convex surface on the outside of the stave's. I also plan to use machine made dowels and shape them by hand or chuck them in my drill and sandpaper them to shape. I will also use any other tools not specifically mentioned.
I plan to make the tools below with the help of my machine tools. They can be made with a bandsaw or a tablesaw or your machine of choice.
"Photobucket"
FOR THOSE NOT MAKING THE TOOLS
From some of the comments, it is clear that some are worried about the tools part, so I have some alternatives for those folks.You can make this authentic bucket with your machine tools if you wish. That said, I won't be giving any details on how to use your machines. This is just to avoid confusion and to keep my own workload at a reasonable level.
1. Stave's have to be concave on the inside. This work can be done on your tablesaw using the 'cove' cutting
method. Info about this method can be found by searching the net or maybe your old woodworking books.
This eliminates the need for the shopmade handplane with the rounded bottom.
2. The dado (groove) which holds the bottom in place can probably be done with a router, but you will need to
construct a curved jig for this to match the concave inside shape of the stave's in order to insure an even
depth of cut. You may have a better way I haven't thought of.
3. The binding lever has to be made as it is necessary to force the rather tight bindings over and around the
bucket. I will be providing a plan for this tool, which is very simple and quick to make.
4. the outside of the stave's have to be shaped convex to match the
inside concave shape. A handplane or spoke shave is ideal for this job, but it could also be done with a power
sander for example.
ADDITIONAL TOOLS NEEDED BY ALL PARTICIPANTS
You will likely need the following:
1. Flat handplane for the 'cooper' angles on the stave's, alternatively your tablesaw with blade tilted to the correct
angle(s).
2. A handrill, electric or not for the dowel holes
3. Marking pencil to mark out the position of dowels, etc.
4. A compass to draw a circle of the circumference of the bucket and the circumference of the bottom.
5. A ruler to draw radii from the center of the bucket circumference.
MATERIALS
There were also some concerns about getting the materials needed for this project. Don't worry! You can use just about any wood you want. However, in the old days the wood was carefully selected and/or treated to suit their intended purpose. The main criteria were, perhaps in order of importance; availability, wood that would not impart a taste to the contents, easy to work with, long life and low weight to strength ratio.
Actually just about any type of wood is ok if you won't be consuming any of the contents from the bucket. So just to keep it simple let us just assume here that you won't be. You can use for example: Pine, fir, oak, alder, beech, elm, ash and, well you get the idea. If you want to drink or eat from it let me know and I will advise you the best choices and/or how to treat easy to get wood to eliminate problems.
PROJECT TIMING FOR EACH STEP
I will set up a fixed amount of time for each step in the tutorial blogs. Many will have time constraints and/or health problems to contend with, so I will try to make a schedule that is roomy for comfort, but short enough to keep things rolling along smoothly. Here is my suggestion for the various steps.
1. Acquire the materials, including for making tools (buy, beg, or steal). - 1 week
2. Make the rounded bottom handplane - 1 week
3. Make the lagging knife and the binding lever - 1 week
4. Cut up the bottom material to final lengths and cut to circumference finish smooth planing and/or sanding. Drill
dowel holes and put together with dowels. Cut up the stave material into long lengths and plane the insides
concave on the inside. Cut the stave's into their final lengths and then cut the dado at the bottom of each
stave. plane, or saw the 'cooper' angles on all the stave's sides. Mark and drill the dowel holes in the stave's.
Prepare the dowels and and use them to assemble the bucket using a steel band to hold the stave's in place
1 week
5. Prepare the band for the handle and bend it so it sits inside the assembled bucket. Scrape off the bark on the
bindings material, split them into two halves, scrape out the dark pith in the center of each half. cut the
hacks in each end of the bindings and make the other necessary cuts. Make extra bindings in case
replacements are needed and leave these in water. Install the bands with the binding lever. This takes
some patience and time, especially without an experienced instructor. Install the handle - 1 week
6. You may want to decorate the finished bucket with a traditional pattern. I will come with some suggestions for
appropriate patterns
Although 5 weeks are set aside this project normally takes about 30 hours or so of actual work.
Each step of the work will be covered by a blog giving material quantities, dimensions, work methods, etc. The above is just to put you in the frame and to get your thoughts on how appropriate the suggested time plan is.
I hate blogs without photos, so I will be posting my own work as we go, plus supplementary drawings where needed covering the how to.
COMMUNICATIONS
I think it would be best if every participant blogs his own intermediate results and frustrations too if he wishes. Questions for me or the other members could either be postd own on their blog, my blog or by PM. The important thing is that we are in touch with each other the whole time to enjoy the experience together and share concerns, successes and failures. The best way to do that is probably for the participants to buddy-up so that we will get email notifications when posts are made to insure we don't miss anything. This could best be done as follows:
1. I'll compile a list of all the known participants and post them. Then it is up to you to buddy up or not.
2. It would help if we use the blog name 'MAKING AN ANCIENT BUCKET- LJ NAME OF BLOGGER'
I hope this rather long and boring blog covers the admin stuff and gives you a rough idea of what's involved. I would appreciate hearing your thoughts on the proposed time-plan or anything else you want to discuss.
I will do my best to make the future blogs more picturesque and less wordy, although I had thought to have a fixed section to add some historical background. That part can be ignored if you are not interested.
Thanks for reading. Now you can go and take a nap.
#3 ·
i dont have experience making a plane, nor building a bucket so i'll leave it up to you to set and adjust the timeline :)
i would like the bucket to be as authentic to history and legend as possible. even though there might not be porridge in it after it's finished… i have a lot of oak at hand, can that be used? otherwise i'll have to buy, beg or steal, hahahah!
#5 ·
Nice timeline and well thought out Mike. This is a project I will do. I might not keep up, but I will eventually join you all at the finish line.
Do you have a recommended materials list for the tools? Will there be any step by steps or plans for their manufacturer or will the blog be geared solely around the bucket itself?
The project is coming at a good time because I have been checking ebay for compass planes and this wooden one would fit the bill for many uses.
Thanks for putting this together Mike.
David
#7 ·
Debbie glad you like the idea.
David I'm glad you're interested and you can just do the project the way that's best for you.This whole thing is just for fun and pressurizing folks and dictating would just ruin the whole project. Those who keep to the time plan will and those who don't won't. No problem as long as we have enough folks hanging with to keep a good dialog going and some visible results.
Helluvawreck I can see you really want to be with, but you are finding it difficult to change your priorities. That's understandable. I had the same problem myself. Nobody will fault you for not being with on this round. You can always do it later if you wish, and I would think most of the others who participated this time including myself will be happy to help you out if you undertake it alone in the future.
#9 ·
Mike
I am still in….......I may dedicate a particular time period each week for it, that will make it work for me. I don't think I will buddy up, I am way too erratic, mostly due to my work schedule. Also will be on vacation for one week, so that may set me back.
Jim
#13 ·
Hi Mike,
I'm in, no doubt, and I want to go the full hand tools way, I will like to even make hand planes, a handmade drill, and so, just for the challange… I will pretend I am the cave man I sometimes feel like. (If I can't I think I have a plabe or two to back me up). Perhaps try several ways. I can't wait. For me it will be the health, but since we have a open time line, I have no worry, I can work a little here and there, and then I will keep up I'm sure.
I will be really happy if you also tell about the history part, this is for me always such a pleasure.
Best thoughts,
Mads
#14 ·
Very interesting topic. It reminds me of a trip I made two years ago to burbon whiskey country. One of the highlights of my trip was the few minutes I had to look around a small factory making oak barrels. Much of it done by hand.
#15 ·
I was just at Saint Croix, and saw this. And when I saw it I was thinking I would love to try and make one…
This is old ship barrels for the gunpowder, when they brought it to the island.
So life is sometimes so wonderful.
Smiles,
Mads
#17 ·
Dennis We will still want to be entertained with your humorous comments, so please don't let us down.
Jim I am very glad to hear that you will be with. We will appreciate sharing the thoughts of your perfectionist mind and the words of your glib tongue.
Servelan I agree. Hand tools haven't changed a lot through the centuries, and most tools like hand plaes for instance are really just a more sophisticated way to hold a chisel, and so on.
Rand Sorry you couldn't join us, but I hope you add your two cents to our posts anyway. Thank you for the complement on my drawing. I am in fact the artistic dunce of the family. My younger son is a fantastic artist and my older one is an art director in an ad agency and also very talented artwise. My older brother was also and art director and my wife is talented at drawing. I constantly ask myself why everyone else in the family got the art gene and it completely passed me by! However, I appreciate your positive comment so much that if you were a good looking woman I would kiss you for it! (end of rant).
Terry I would have been glad to join you on that trip if they were making brandy. Yes, coopering is amazing, but we aren't going to be doing that in this project. We have a much more flexible approach. Read on.
Mads I know you aspire to being a caveman, but to tell you the truth, I just don't think that is going to happen. I and probably many others here on LJ regard you as more of a renaissance man who lifts our spirits and shows us how to make good woodworking tools, not chipped Clovis arrow heads. Sorry, you will just have to live with it.
Thanks for those great photos . From looking at them, I can say, almost with certainty, that these barrels are made with the lagging method and not the coopering method. That's because The stave's are all different widths and the walls of the barrel are straight up and down. That's how I want to make mine.
#18 ·
Mike, yes, old helluvawreck is very tempted; however, I probably will not this time but you can believe that I will be a lurker watching on just like one of those big catfish sitting on the murky river bottom. I can tell that I will learn a lot of worthwhile things that will serve me well into the future. Just please try not to step on me as you're crossing the river to the other side because I sure wouldn't want to be injured while being just a bystander that is looking on. That would be a little embarrassing and undignified. :)
#20 ·
Sounds like a very interesting project but I can only participate as an observer, am in the middle of recovering from a severe cough and colds! I have been coughing so hard it feels like I am coughing up my insides! I hope none of you get a case like this. This has made my chest so sore that it feels like I have been through 12 rounds with Mean Mike Tyson!(without the ear biting!)
Erwin, Jacksonville, FL
#23 ·
Nice projekt you have here :)
" The dado (groove) which holds the bottom in place can probably be done with a router, but you will need to construct a curved jig for this to match the concave inside shape of the stave's in order to insure an even depth of cut. You may have a better way I haven't thought of."
The tool wich is normally used to make the groove in a bucket is a homemade plane i only know the danish for. Its called a "krøjshøvl"
Good luck :)
#24 ·
Awesome post Mike. I think you have it very well thought out and covered all the bases. With this experience under out collective belt, I can hardly wait to start our long boat and prepare for the raid on Merry Old England just the way out fore fathers did it ;-)) We can carry our provisions in out water tight wooden barrels.
#26 ·
Napoleon There is no plane for this method. The plane you are talking about is used in the making of coopered barrels.
This bucket is made with an entirely different method. Coopering was a further development of 'lagging'. In 'coopering' the groove is a shallow female 'V' groove which is planed around the inside top and bottom of the barrel. The top and bottom pieces have matching male 'V' profiles which fit into the female groove making a very water tight joint.
In lagging, the water tightness is caused mainly by the swelling of the container after it is filled with liquid.
The groove in lagged containers is deep and square at the bottom.
I'm afraid the confusion is all my fault, as I forgot to include the dado on my drawing at the top. I will have to correct that. The word 'Lagg' actually is a reference to the dado that the bottom fits into.
I hope this will clear up any misunderstanding, as quite a few folks seem a little confused between 'coopering' and 'lagging' I will include some small drawings in my next blog to clear up this point.
