As a new woodworker, I am trying to learn as much as I can about hand planing as I don't have the means right now for a jointer/planer. I've read as much as I can about hand planing and watched many hours of videos, but there's still lots of unanswered questions. I have a few here and I hope it's not too much for a single post.
First, why does the sole of the plane have to be perfectly flat? For longer body planes like a jointer, I've read that it doesn't have to be perfectly flat only for shorter ones like a No. 4. There's lots of information on flattening the sole but no discussion as to why it has to be done and how it helps.
Second, why isn't the front of the sole inset like a power jointer. On a power jointer, the infeed end of the table is set lower than the outfeed end. It works the same way on a router table when you want to use it for jointing and even the power hand planer. With the hand plane, however, the front and back of the soles are pefectly planar with the tip of the blade protruding. The jointer's mechanism makes a lot more sense to me than the hand plane.
Third, how much of planing success is technique and how much is due to the mechanics of the tool? I've watched experts explain how to plane a perfect 90 degree edge and how to plane two opposite sides of a board to be perfectly parallel and consistent in thickness end to end. When I tried to do it, I was able to get a flat surface and a perpendicular edge to it, but discovered that the board became an unusable trapezoid. Was I pressing too hard on the front knob or was my blade off?
I'm even more confused when I see other woodworkers using edge guides and shooting boards. Obviously, it shows a limitation of human technique and mechanics in getting accurate results. It makes me wonder whether success with the tool is really just about look, feel, listen and feel. The idea of depending on your senses for critical precision scares me. I would hate to ruin a nice piece of mahogany because my senses were "off."
I sometimes wonder whether this whole hand planing is just a futile exercise in elitism and machismo. The folks at Popular Woodworking spend an inordinate amount time extolling the virtues of hand planing with Schwarz as its highest guru. The whole thing reminds me of the cheesy heavy metal videos back in the 80's where every band had to have an acoustic guitar ballad to appear sophisticated.
Perhaps, the whole hand plane thingy is just a waste of time. Should I just wait for an affordable jointer/planer to make itself available on Craigslist before attempting to build anything elaborate?
