I will say I am keeping my fingers crossed I am one of the super majority that have no problems. It has been a great saw… Whisper quiet… As far as saws go, and works perfectly with my dado blade set. Is it perfect? No. But for the price it has good precision and makes cuts that most portable saws cannot do. Does it beat a cabinet level shop saw on durability, nope, but definitely on price. Not to mention the space… And even though it is 200 pounds, it is very easy to move and then lock in place. Yes capacitors are always an issue, especially when you go cheap, but most small engine repair or electronics shops can probably troubleshoot a startup capacitor issue and replace it with a much higher quality Japanese brand, if needed. I do wish the t-square is a little less finnicky, but once you get it adjusted right it's fine. Make sure to follow the set up guide and adjust your blades to ensure complete accuracy. It is not hard to do. Good luck on a well priced contractor saw that can perform work of much more expensive options. Now onto figuring out how to mount the router table on it. I saw previous shots here on that.
