Can I repair this JET table saw?
7.3K views 7 replies 6 participants last post by  Jeff28078
#1 · (Edited by Moderator)
I have a Jet Contractor TS that I bought about 10 years ago from an add in the newspaper for $150. I don't remember exactly, but I think the guy said it was about 10 years old then, making it about 20 years old now. It was stored/used in an unheated barn then and moved to my garage at my old house (heated, but only when I was working out there.) Now it is stored in my heated/AC basement workshop, but I haven't used it since we moved into this house 3 years ago. Instead, I have been using a portable delta model to rip down 2X stock to finish the rest of the basement.
I want to sell both of the saws on Craigslist and purchase a cabinet saw. However, when I fired up the Jet, it starts very slowly and finally reaches what seems like its top speed. As soon as I start feeding anything, even soft 3/4 poplar, the saw will stop and most of the time trip the 20 amp breaker. It has a new, sharp blade, so that is not the problem. The Delta, plugged into the same outlet, does not have any problems ripping 2X stock.
I am thinking the Jet has a motor problem. Is there anything I can do to tune this up? I don't want to sell it in this condition.
#3 ·
I would agree with checking all the moving parts to ensure nothing has frozen. If you determine it is the motor, sometimes just blowing the dust out helps. If it's a capacitor they are fairly cheap and easy to replace. There may be a centrifugal switch that's acting up. If you don't want to troubleshoot the motor, you could take it to a motor shop for diagnosis…the one I use doesn't charge for the diagnosis if you have him do the repair.
#6 ·
Mr. Childress makes a good point and that is certainly an easy one for you to check yourself. While you have the belt off, check to be sure the bearings on the motor spin freely as well. As far as the electrical is concerned, I used to service automotive shop equipment and the most common cause, when I saw a problem like you are describing, the problem was usually a start capacitor on the motor. Most industrial grade electric motors use a start capacitor to add a little extra juice to get the motor up and running on start up. First thing to check is to see if there is a start capacitor on your motor. Most motors will have a little sheet metal bump (not the one where the wires are tied into the motor) that houses the capacitor. If that capacitor is bad (and after 20 years, I would not be surprised at all), the motor will usually never get up to full speed and power. These usually are not difficult to replace. The hardest part is finding the appropriate replacement capacitor. If you aren't comfortable with it, any electric motor service shop should be able to do it without spending too much. They, of course could also tell you for sure if that is the problem.
Doc
