Cabinet Doors for Bathroom Vanity - Wood Choice and method to make.
1.4K views 8 replies 5 participants last post by  The__Dude
#1 ·
I have a planer, table saw and router.
I have made furniture stuff, but never doors.
I ordered an adjustable toung and groove router bit set
These are simple shaker style doors to match the new bottom shaker style cabinets
I was planning on soft maple for the styles/rails
Not sure about the center wood, they will be narrow doors. Guesssing 1/4" maple plywood?
the 2 larger doors will have mirrors in the center.
Not sure how I do the mirrors yet, I think I just route out the back grove, install mirror and then trim piece over to hold it in.
leaving 1/8" gap around mirror and wood for movement.
The doors will be painted off white, with an attempt to hide any wood grain.
Any tips or suggestions?
#7 ·
Sounds like a good plan to me. I was thinking poplar would be another good option for paint grade. I used 1/4" MDF for the center panels for our kitchen cabinets. Tempered hardboard is a different product. Never thought about using that for panels. I made some hollow, flat panel entry doors on my house with the 3/16 tempered hardboard skin on each side, so I guess it may work. One of those doors is in our restroom.
@JackDuren would MDF panels be okay in a bathroom? I don't know. Otherwise maybe 1/4" maple or birch plywood?
#8 ·
1/4" MDF is ok, just be aware it can vary in thickness enough that they may not fit in the groove on your bitset. If the T&G bit is actual 1/4" that's probably going to be the case. A lot of MDF is 5 or 5.5mm. If the panel is loose you can caulk the gap. I think its a good idea to caulk them anyway when painted.
You can also use 3/8 MDF, which is a good choice too, it allows you to use the tongue part of the bit and gives a little extra weight to the door. I think self closing hinges work better, too.
