I just picked up my first bandsaw on Friday and I'm in the process of figuring everything out with it. I spent the weekend getting it into good running condition and just learning the machine and setup. In case anybody is interested, it's a 1970s Craftsman 18" Band saw by Parks, with a 12" cutting height and a 1hp motor. I know it's a little low on power, but needing new tires, thinking hard about putting new guides on it, and a good blade will put off a motor upgrade for a bit.
So on to my real question: I plan on mostly using the saw for resawing, and have plans of building a large deck that I will deck with locally harvested black locust. I want to shop for a good resaw blade, but don't want to waste too much money trying out every blade on the market. Of course everybody says timber wolf is the best, but they make a lot of blades. Black locust is a pretty tough wood with a known blunting effect, so would resawing a lot of it justify the nearly $200 cost of an 11' carbide tipped blade? Or would a regular blade have some life to spare after sawing several hundred bd/ft of black locust? Also I wasn't sure about blade width. The blade tensioner has indications for up to a 1" blade, the wheels are just a hair over 1.25" wide (no lip), and the 70s sears catalogues only gave part numbers for up to 5/8" blades. I figure a 3/4" blade would be fine, but wasn't sure if a 1" blade offered much better resawing.
