Applying Oil Based Varnish Over Water Based Stain
43K views 8 replies 9 participants last post by  wapakfred
#1 · (Edited by Moderator)
Happy Holidays All,
I am building a wagon for my daughters and they would like it finished with a pink stain. No surprise there. The only stain I can find that in pink is water based. I would like to top coat with an oil based varnish/poly for durability and preservation from high FL humidity and UV. It will be kept in the garage when not in use but the sun here in FL is brutal. I have a couple questions.
Do I have to use an oil based varnish/poly?
Can I apply the oil based poly on top of the water based stain?
#3 ·
Johnny, I would use a water based poly, such as Target's EM9300. An alternative would be to apply a super blonde shellac and put the oil based poly. Make a sample board because the oil will darken the finish somewhat. Finally, you might try using the oil over the dye without the shellac, but, again, make a test board. FWIW
#4 ·
Absolutely, as long as the stain is completely dry, you will have no issues. I use water base stain under oil base finishes all of the time with out problems.
#7 ·
Check the color effect of the poly over water based stain to be sure its still what you want, but you can safely use poly over water based dyes. I've done it in most of the furniture I have built and have never had a problem.
#8 ·
I've used oil based product over water based stain hundreds of times. Just wait the appropriate time, recommended by the stain company, and go for it.
That aside, have you looked into dye? It's MUCH more pink, if you want that.
#9 ·
You will be fine, but the advice above (dyes, the color shift, etc.) is spot on. You might want to reconsider the oil just because of the color.
