Not a fan of do-all blades at all. Of them, I would tag the Ridge Carbide 2000 the best.
But, a Diablo 60 or 80 tooth crosscut and 24 tooth rip will serve you better. Right blade for the right job. I mistakenly put up with them for years on both the RAS and TS. I now know better. I run thin kerf as I have a 1 3/4 HP in the TS, but am changing to a full width in the miter saw. When I get a 3 HP cabinet, I may change to full width on the TS. More stability especially doing things like glue line perfection.
As has been covered in this forum before.
Ridge Carbide, Freud, CMT, Amana, Forrest, etc. are the premium blades professionals prefer because the carbides are thick enough to be sharpened many times. I suggest you go read their WEB sites and glean the common use and advice. Obviously, they are all the best of the best, so put on your "Madison Av. filter" on first.
If you do not plan on resharpening more than a couple of times, then the second tier like Diablo, Mamba etc. Quality and performance is the same, just less carbide and half the price.
I used an expensive Freud Fusion on my TS. It may be great for a job-site where you are not going to be changing the blade, but it did not cut as well as the pair of Diablos for about the same total price. One size fits… one. Not all. Get used to changing the blade.
In the other side, really poor blades cost almost as much as a Diablo or equivalent. I made the mistake of thinking I should use a cheap blade where I know it is going to be harsh. But I found on a cement board blade, the cheap blade lasted a dozen cuts.( Avanti) The 4 tooth Diablo finished the house and still looks good. I had a cheap "hit a nail" blade. ( DeWalt) Lost a tooth first time it did. I now keep a Diablo demo blade.
I am just starting to play with 7 1/4 blades on the TS. I had not thought of that before. I need to make new ZCIs with splitters moved way forward. Not convinced yet but folks doing lots of small work seem to prefer them.
