Which digital angle gauge to get?
1 reading
2.3K views 10 replies 8 participants last post by  Loren
#1 · (Edited by Moderator)
I have an application where I need a digital angle gauge (for work actually, not actually for woodworking). I need high precision, repeatability, and magnetic, and while sifting through the reviews and other topics I thought I would just ask a new question. Is there really much difference between the Wixey and Beall? Are there other brands to consider? What are all of your thoughts on which one to get?
Thanks!
#4 ·
The Wixey has a "zero" button, but does it also have any way to get back to absolute reference zero? If I zero it, is there any way to get it back to the absolute zero point without having to find another calibrated flat surface?
#6 ·
I have the Wixey that Madmark has and it's great for what I use it for. However, you said you need "high precision"? How precise? The Wixey has .1 deg resolution and +/-.1 degree for type 1 model or +/-.2 for the type 2 model. They have a model with a built-in level that I believe uses the level as an "absolute" zero and has a function to zero it to a reference angle as well. The type 1 and type 2 don't have absolute zero, you have to zero it to a reference surface.
#10 ·
I have both the Wixey and the iGaging devices.
I have had the Wixey for several years and it has been fine, but I now prefer the iGaging.
My Wixey uses a CR2025 that has an annoying habit of turning up dead at inopportune times … like when I need it. The cover on the battery compartment also comes loose and drops off (fixed that with some painter's tape). My Wixey also only measures down to 1/10th of a degree.
The iGaging uses a 9-volt transistor radio battery, which should give pretty long battery life, and the battery compartment is secured with 4 screws. The iGaging also registers two points to the right of the decimal (hundreds in 5/100 increments), which results in a slightly more accurate angle.
To be fair, my Wixey is 5+ years old, and I understand they have replaced the CR2025 battery with a AAA cell.
