I'm attempting to remove and replace the right side grinder wheel on my Delta 6 inch grinder, but the nut that retains the wheel is very tight. I've tried to hold the right side wheel and loosen the nut, but as I use a wrench on the retaining nut my fingers are not strong enough to keep the wheel from moving. Also tried holding the left side wheel with the same result.
I think I need some mechanical advantage to keep the wheel (and, of course, the motor shaft) stationary. But I am concerned that if I try to restrain either wheel with a pliers, or channel-lock, or something similar that I will crack, or somehow damage, the wheel. And I want to keep that grinding wheel for future use.
Am I right to be concerned about grabbing either wheel with a tool? I sure don't want to cause some unseen damage and then have the wheel destroy itself the next time I reinstall and use it.
Any ideas? Not sure how to proceed.
