Lee Barker - I guess "occasional" is subjective. I'm not sure I understand your reasoning that the drill is more efficient because it is designed to be used one-handed. What can you do with that other hand to increase efficiency? Me, I have both hands on the drill to try to keep it perpendicular to the material.
Here are the efficiencies I find using a plunge router:
1) All my drills are cordless, so they turn fairly slow. Even a corded drill is only turning about 4k rpm. That's got nothing on the drilling ability of my router doing 22k rpm. The router is easily drilling each hole in half the time or less.
2) Even if you are really good with a drill, getting holes that are perfectly square to the face of the material is tough. Slight variations in the angle of the hole mean a shelf that is not steady. The base on the router takes care of that problem.
3) If you are drilling very many holes the one-shoulder-up posture of drilling becomes very uncomfortable. The plunge router is used with both hands, creating symetrical posture and motions … much more ergonomic.
4) The tape on the drill bit thing is hard to setup and adjust accurately. Drill a hair too deep and your tape gets pushed back and wadded up on the drill bit. The depth stop on the router is a breeze.
There's more than one way to skin a cat. If the drill works for you, that's great! For my purposes, the router is the ticket, and I wouldn't go back to drilling.
Here's a short video I put together showing how my setup works.
Cheers!
