What wood should I use if I'm going to paint it.
4K views 15 replies 15 participants last post by  BurlyBob
#1 · (Edited by Moderator)
I'm going to build a small stand similar to a night stand. I think the person I'm building it for wants it painted. I like red oak but I don't want to use red oak if it's going to be painted. I thought of poplar because it would be cheaper than oak but I want a wood a little harder than poplar. Any suggestions?
#5 ·
I would pick Poplar, soft Maple, Southern Yellow Pine, mostly depending on price. Not the dead low end of Janka, but all under 900. So none are hard. All are easy to work, and will be plenty stable for woodworking uses. All will take paint well too.
If the piece is well supported, and doesn't have large overhang ledges, don't rule out MDF, though the edges will need some form of Fascap tape or similar, as they are like a sponge, and getting great pain on them isn't easy, unless you totally cover them. This same thought can also be applied to Plywood, though with plywood I would definitely suggest a good primer like Kilz to stop the telegraphing of wood grain, through the paint. Using Kilz even on hardwoods, or soft with a paint finish is always a first step for me anyhow, same reasoning, it stops the telegraphing of grain lines through the paint.
#12 ·
+3 What they said above:
Use any locally cheap white hard wood. Such as; Alder, beech, birch, maple, or poplar.
Large grain woods like ash, or oak; will have grain print through without filling.
Using MDF, or birch cabinet ply with hardwood edging would also work well under paint. Can use drywall Spackle as quick dry filler too.
Best Luck.
