Waterbased poly and brush marks....aahhhhhh
50K views 44 replies 24 participants last post by  CaptainKlutz
#1 · (Edited by Moderator)
So I'm finishing a cherry surface. I'm sanding with 220/320 between coats. When the waterbased poly goes on, it looks real nice. Im being carefulto work from wet to wet and using a highh quality brush. After it drys, it shows thick brush marks. Any suggestions how to get these out?
#30 ·
I have almost finished hand planing the Douglas Fir hallway . The blocks are set in squares and mainly I wanted them level rather than left as they were 100 years ago . One thing I found was planing the squares diagonally was the best way .Using a variety of planing directions was the other method .The floor varnish was gradually applied each day to avoid dirt being walked into the surface as soon as it had been planed. The trick was to cover that area with a clean rug and then varnish after everyone was in bed , last thing . It was impossible to leave a scratch free surface from the beginning .That can be attended to in a later stage . The water based varnish does not stretch a skin tight surface as it dries . Neither does it fill in the numerous tintack holes near doorways and staircase bottoms. They remain as part of the history of the house. But varnish will not fill them in . The satin finish takes about three layers to get a reasonable surface . Attending to the scratches from all my planes is partly solved with a flap wheel .But one of the most effective tools is a triangular paint scraper given an edge with a coarse diamond plate .The "edge"is almost 90 degrees and needs constant reshaping to keep it working . For the planes I found one of the most useful was a small six inch long wooden coffin plane . No matter how sharp my planes were the best way to level the high blocks was straight across the grain and then changing to 45 degrees . No difference really showed up if you compared the plane blades apart from the old Sheffield blades in the wooden planes . In different situations each plane became the star of the show They all performed well and all became blunt after about 15 minutes . The RB10 with new blades was valuable near the edges being a rebate plane . With a Stanley No 5 I tried a very fine sharpening and a super thin blade slice to shave the top surfaces of the varnish bumps . That worked quite well . I will test the oblong sander plate to compare . If I only sand the varnish it will not clog up with the Douglas Fir resin . That resin sticks to the sole of any plane ,whether steel or wood . The 2 foot wooden planes I used had a Sorby blade and a Brades blade .The Brades stayed sharp longer than the Sorby . When I took it to resharpen , some of the edge could still slice paper .Mainly the water based varnish will not darken over time . It`s easy to repair surface scratches .Odour free varnish removers are a real bonus . I doubt if I will ever need to use that again though . Scratches only matter where the light reflections show them up . Light through the front door windows along the hall is the crucial test . Then areas below the lights . A trickier job than a work surface . I have to allow my wrist and finger joints time to recover now .
#31 ·
Your're all done now and the project looks great. Good job.
For your next project consider the following:
Taclon brush - You can get them from Amazon or most stores that sell artists supplies. Bristles are fine and dense. Works great for WB finish (and oil based too).
Foam roller - Leaves a much finer texture that levels out better. Use light pressure to avoid ridges left by roller edges.
LVLP spray gun - Low Volume Low Pressure (as compared to HVLP). Works with small compressors, fine soft spray, low overspray. Works great with WB products using 1.3-1.5 needle set.
#32 ·
+1 for spraying poly. For me trying to brush/roll poly was a p.i.t.a. because at best there was always a little something somewhere that stood out. There is a wipe on poly but I couldn't see doing a large project with it.
You should be able to get a nice finish with your Earlex using 1.0 or 1.5mm tips. You should have less headaches and time saved.
#33 ·
i use polycrylic from minwax and I apply it undiuted with a rag as though I am doing a french polish. I buff it untill its tacky and then leave it until its dry, which is only about 5 minutes. then I repeat it without sanding between coats. It goes on quite well. It is slow, I would expect a tabletop that size to be about 6 hours of work.
#35 ·
Antique thread - But to help others:
IMHO - best WB poly retarder is 2-Butoxyethanol, or commonly called - Butyl cellosolve
Is a very slow evaporating solvent that is compatible with water/alcohol/glycol finishes. WB finish mfg often use small amounts (< 1%) to improve flow out. It is easy to recognize as it has sickly sweet odor. Adding 1-5% drastically improves flow out of WB finishes in low humidity conditions, and makes spraying WB easy even in 100° temperatures.
It is used as food additive, and in cleaning agents. BUT California calls it a hazardous material, with a 25ppm 24 hr exposure limit. Large exposure give most people a horrible headache that takes many hours to dissipate while liver/kidneys remove the solvent from your body that was absorbed thru skin.
Proper PPE is required even for WB finishes, so adding Butyl cellosolve does not change the need to use a respirator in closed spaces. Be safe, not sorry; when using solvents or finishing materials.
#37 · (Edited by Moderator)
The water based polyurethane dries very thin when using a brush so I used a plastering trowel . It has a plastic sole with thin flexible edges . The surface is much smoother , but leave any doors open when you do this .Draughts under both doors dried the surface too quickly for about 12 inches .It makes the varnish wrinkly and a bit flaky . After sanding and scraping those surface patches the dust would fill a tablespoon. Not a major disaster . The varnish resisted sanding well . It should last a long time
#38 ·
Temperature and humidity have an affect on water based poly. I find that temps between 60 and 70 degrees produce the best results. Below 60 it can end up with any fine "dust" particles that may be in the air trapped in the finish. Above 70 the finish sets up too quickly for it to level out. Obvisously low humidity will also cause the produce to set up befoe it levels out.
Third factor is the thickness of the product. I do thin it out with a little water sometimes. It does not take much so test it. Spraying water base poly has not worked well for me either and instead of brush marks I end up with little round spots; or you spray too much and get runs.
Someone mentioned a retardant for water base poly. That sounds like a workable possibility. I see the General Extender suggests adding 10 to 15%. Floetrol is another but there is some concern that it will cause the poly to yellow over time. It was designed for latex paint originally.
#39 ·
I see the General Extender suggests adding 10 to 15%. Floetrol is another but there is some concern that it will cause the poly to yellow over time. It was designed for latex paint originally. - LesB
GF Extender is Propylene Glycol (PG) and water.
A portion of the PG is able to react with most clear WB wood finishes and rest evaporates slowly. Used at high levels it will make the film softer, and will change the sheen.
FWIW - For same cost as pint of GF Extender, can buy a quart of PG from Amazoo and make ~3 gallons of extender.
Floetrol is mixture of PG and water, with white color is derived from a anti-microbial compound, Benzisothiazolinone. It is not 100% compatible with modern paint formulations. It is not intended to change viscosity of paint. It only impacts flow out, and wet edge joining.
A better product is XIM Latex Extender, as it does not yellow with age. It will reduce viscosity while improving flow out. Can can cause runs on vertical surfaces, so add sparingly.
Both of these Latex extenders are only recommended for pigmented WB latex/acrylic paints, as use in clear top coat will change clarity/sheen.
Most of the newer Italian made commercial WB polyurethane sell a WB poly extender that is blend of Propylene Glycol, water, and 2-Butoxyethanol; optimized to improve flow out and slow dry time for both 1K and 2K formulations. Here again, you can buy quart of 2-Butoxyethanol, and quart of Propylene Glycol for less than cost of quart of WB poly extender, and DIY over 3 gallons of extender.
Chemistry is FUM!
#42 ·
Chemistry is FUM!
- CaptainKlutz
So what was the ratio to make that 3 gallons?
#43 · (Edited by Moderator)
The last floor area to be varnished continued into the toilet area . The water based varnish was applied by brush after the first planing to keep each part clean. Then the whole area was coated using the plastic trowel . There was never any spiky uneven finish that you get with oil based polyurethane. The surface was just left alone to dry . The final layer was thicker than a brush could apply and the whole job was much shorter . The thicker layer took sometimes over twelve hours to dry. But you only have to do that once . Then just admire the glow in the wood .
#44 ·
So I m finishing a cherry surface. I m sanding with 220/320 between coats. When the waterbased poly goes on, it looks real nice. Im being carefulto work from wet to wet and using a highh quality brush. After it drys, it shows thick brush marks. Any suggestions how to get these out?
- umbach
I always just hand apply poly, or poly mixes, oil, or water based with a clean, lint free rag. Spraying also does a fine job, but then you have all that clean up of the spray equipment. Hand applied, just toss the rag in a fire, and you are done. I figure if the soiled applicator of oil based products is a fire hazard, I just cut to the chase, and ignite them outdoors in the fire pit. I've always wondered why the sprayer itself wouldn't also be a fire risk, before cleaning? All I know is I only spray if I have too. With poly/poly mixes you don't have too, and still get wonderful results.
#45 ·
Most of the newer Italian made commercial WB polyurethane sell a WB poly extender that is blend of Propylene Glycol, water, and 2-Butoxyethanol; optimized to improve flow out and slow dry time for both 1K and 2K formulations. Here again, you can buy quart of 2-Butoxyethanol, and quart of Propylene Glycol for less than cost of quart of WB poly extender, and DIY over 3 gallons of extender. - CaptainKlutz
So what was the ratio to make that 3 gallons? - tdwilli1
Lol
Very few folks need 3 gallons of WB retarder:
One gallon of retarder extends between 12-25 gallons of top coat (at 5-10% addition)? Most WB top coats don't recommend more than 5-7% thinner/retarder. Quarts of PG/Glycol Ether will last most hobbyist many years.
Retarder blend depends on brand of WB finish?
GF Enduro Poly uses 3:1:5% of water:pG:2Glycol ether
Milesi has several different WB retarders. Fast - 4:1 water:pG, Slow - 1:3 water:pG, 100% Glycol ether, and 4:1:5% water:pG:Glycol ether blend.
Can't find my Renner retarder SDS, believe it was similar water:pG:2-Butoxyethanol mixture with much less PG and more glycol ether. Also has a biocide to prevent mold growth.
Environlak WB Poly retarder is 100% of slightly different glycol ether (Diethylene glycol monobutyl ether) which is not rated as 'green' as 2-Butoxyethanol, and evaporates slower.
Target WB Finishes use a generic spray retarder, that is 1:1 of water:Dipropylene Glycol Monomethyl Ether blend, again a slightly different glycol ether solvent.
Additional reference: Water has relative evaporation rate of 0.3 (using butyl acetate as 1.0). 2-Butoxyethanol evaporation rate is ~0.06, Dipropylene glycol monomethyl ether evaporation rate is ~0.03, and Diethylene glycol monobutyl ether evaporation rate is ~ 0.02. As you can see most of the glycol ether's have similar evaporation rate, and are usually interchangeable when used at low levels. Can use any of these glycol ether's found locally, with 2-Butoxyethanol or Butyl Cellusolve being sold on Amadud. I can get gallons of 2-Butoxyethanol as Dow EB for ~$40 locally. If you need to compare evaporation rates of other solvents, suggest the Producers Chemical PC Solvent Chart PDF
Please note that each finish, ambient weather conditions, and project; dictate different retarder needs. A single part acrylic poly is usually happy with PG & water, but 100% solvent works too. A 2 part system prefers a solvent blend that evaporates before the film cures, with zero PG to avoid blush if humidity and temp is high. When spraying a vertical project, adding to much thinner/retarder creates sag or runs (as WB coatings have thicker wet film build than solvent). A vertical project would need a mid-rate evaporation solvent that dissipates shortly after spraying, and and slower solvent to aid flow out. A sprayed flat project could use most any retarder blend.
The key to all of this is chemistry is learning your finish material, learning how weather changes film behavior, and making adjustments as needed.
