wagner 590 review
9.4K views 3 replies 4 participants last post by  hokieman
#1 · (Edited by Moderator)
Wagner - 590 (Rating: 5)
Overview Of Wagner 590 Review
Wagner is a big name in the paint spraying game for making economical options that are generally most suited for do-it-yourselfers.
As is true with any tool manufacturer, some of what it has to offer is really great, while some of its other tools fall a little flat. Today, the goal is to determine which of these categories the Wagner Flexio 590 falls into.
Most shoppers will probably find that there are departments in which the Flexio fits both categories.
In terms of high-quality performance, there are certainly some aspects of this tool that the average do-it-yourselfer will probably appreciate.
The biggest draw for the Flexio 590 is probably its versatility, which is not necessarily something you see with bargain-priced options.
The iSpray nozzle is highly adjustable, which means you won't have any trouble changing the spray pattern vertically and horizontally for a wider range of use.
Unfortunately, the iSpray nozzle is also a vulnerable component of the tool. We found that this feature is a little bit finicky and prone to clogging, which can prove frustrating.
Still, if you are an average user looking for an affordable way to lay a lot of paint, the Flexio 590 may very well still seem appealing.
You can read the details and comparison of Wagner spray painters . As I learn alot from this source.
Specifications
Company: Wagner
Model: Flexio 590
Weight: 10.15 pounds
Dimensions: 15.9Ă—6.7Ă—13.9 inches
Features
Detail Finish Nozzle: Perfect for Furniture and Fine Finish Painting
The Wagner Flexio 590 is mostly designed for bigger jobs, like painting the walls of a home. But, in keeping with the spirit of versatility that it exhibits in the iSpray feature, it can also be used for detail-driven projects.
The detail finish accessory is a great way to put the finishing touches on a project that requires a little more skill and attention.
The good news is that this tool is much better at handling clogs than the iSpray nozzle.
Easy to Clean
We mentioned earlier that this tool is overly prone to clogging, which is going to be true no matter what you do. However, the fact that the spray gun has been designed for easy cleaning is still a big plus.
This optimization is born mostly of the fact that the gun is easy to break apart. Wagner calls this the Lock N Go design.
The feature also allows for easy, stress-free removal of accessories and attachments, which is, of course, also good to see.
iSpray Nozzle: Providing Versatility
The iSpray nozzle is a very convenient way to adjust paint spray patterns to accommodate the unique needs of a given job. The more you are able to adjust a paint sprayer, the more you will ultimately be able to do with it.
#2 · (Edited by Moderator)
So how heavy is the unit when empty? Handle and container? Weight would be a limiting factor when doing bigger jobs but of course it's not designed for large jobs. Some guy on Amazon complained that if he had just rolled his wall out, he would have gotten the job done in half the time.
One claim to fame for this sprayer is that it can spray "unthinned latex." So it's an airless sprayer, which is intriguing, since once in a while I want to spray latex, which requires a lot of thinning to work with my HVLP spraying rig.
