I'm adding a 15'x15' loft over one side of my shop. I'm using 2×8x15 wood joists. However, the pieces are too long to put into place as a whole piece. I was thinking about cutting them down and splicing them back together once in place. Roof is already on so there is no way to do it the easy way.
Here's my plan:
Would it matter if all were cut in the center or should I stagger the cuts of each board? How long should the splice be? The span is 15'.
Any better ideas?
The loft will be used mainly for storage (scraps of lumber, holiday stuff, etc.). There is no crossbeam running down the center.
Here's my plan:
- Cut the wood into two pieces
- Put the two pieces together in place and splice them using 1/2" plywood, glued and screwed (both sides)
Any better ideas?
