I finally cleaned and added the rail assembly to a used industrial sawstop I got. I noticed the left side of the fence has seen better days. It's been hit with a dado blade and dinged up.
Sawstop wants $45 for a pair of panels to reface the fence. I do need a few other smaller parts from them so that's one route.
I then saw some pics of a guy who bought essentially 1"x3" aluminum extrusion and used some oval threaded nuts to attach the panels to the fence. Probably be around $80 in aluminum. My concern is running a beveled piece along the fence and have it slide into the a slot on the new aluminum extrusion. A flat auxiliary fence could be used I guess.
I could also get a piece of 3/4" HDPE plastic locally and use the clean right side of the fence as a template and follow it with a bearing bit on the router table. Probably the cheapest route.
