Rolair JC10, super QUIET! compressor
14K views 13 replies 11 participants last post by  marvinlee
#1 · (Edited by Moderator)
Rolair - JC10 (Rating: 5)
If I had one word to describe this compressor, it would be QUIET!
This is a 1 HP, super quiet, oil-less, single stage, two pump, 115 volt, 8 amp, that runs at 60 dB!
It runs one nail at a time with no problems. I have used it from framing, finish work and wood working projects.
Not much else to say. Did I mention it is QUIET?
It is a little pricey, compared to other compressors but is worth it in my opinion.
Eric
#2 · (Edited by Moderator)
I had a Campbell Hausfeld 1 gal pancake compressor for a few years and really liked it - except for the racket it made. I even ran a framing nailer with it a few times and it kept up - as long as I didn't go nuts with the gun.
Last year, I got the Senco 1 gal and love it. Very quiet, and supports all of my nailing needs.
#6 · (Edited by Moderator)
It is great that a manufacturer is stepping up and offering a quiet oil less compressor.
Looks like the pump is similar to my Thomas T-2820ST. How long does it take to refill from the bottom of it's cycle?
#8 · (Edited by Moderator)
I've had a RolAir that is about 22 years old that I have used and abused beyond belief. Have only had to put a $17 head gasket in it and it's still going strong. Their a little more money and usually have to be ordered but are well worth the extra $$.
#9 · (Edited by Moderator)
Nice to know there is a quiet oil less with a quick recovery, with Thomas AirPac in limbo, I'll have to give Rolair a serious consideration when my Thomas wears out . I always like to have an oil less set up for trim and finish work, and I really can't stand the racket of those little pancakes. The Rolair wheelbarrow compressors are pretty popular in these parts.
#13 · (Edited by Moderator)
Cool video. Eric what is the max pressure of the unit? The Porter-Cable says 150. I own an All-Power 4.6 gal. twin tank that is super quiet. To tell you the truth, the motor looks and sounds the same as mine. The only complaint I have with mine is the max 110 psi. Sometimes I do not believe I am getting that much. 18 gauge gun runs fine. 16 gauge you have to watch and make sure they being sunk. You feel like you'd like to turn her up a little more but she's maxed out, ( that's what she said) lol. Thanks for the review. Looks like a nice machine.
#14 · (Edited by Moderator)
I have the Rolair JC10 and it truly is quiet. The unit sits on a low shelf in the garage, so I've added a 45-degree 1/8" brass fitting to make the output pressure gauge tilt upward for easier reading. The next step is to add a quarter turn brass tank drain valve and that will be the last modification. It is a very pleasant compressor to live with.
