Robust Sweet 16
2 reading
28K views 23 replies 16 participants last post by  JethrowClampett
#1 · (Edited by Moderator)
Robust - Sweet 16 (Rating: 5)
I treated myself to a retirement gift. I could not have made a better choice.
I have been using using this for 2 months now. I wanted my review to be based on what I've done with it.
I looked at everything I could see in person,and read for hours on the web what others have to say about their lathes. I had certain needs that had to be filled, plus I wanted options to grow into as my experience grows.
My main concern was getting it into my basement shop. I wanted bigger capacity than the Jet 1220vs I started out with. Variable speed is important to me. Indexing is very important to the projects I want to get into. Quality and safety go hand in hand, you can't have one without the other. I wanted a powerful motor with reverse. Many lathes out there will do all of these things. For my situation, this was clearly the right choice.
This is the shortbed, 2 h.p. version. It's a gap bed lathe. A section comes out of the bed that can be attached 2 different ways. 1 way is to increase swing over the bed, the other to increase spindle length capacity. This puts a lot of lathe in a small footprint.
The first 2 pics are of a big slab of cherry, 18" x 18" x 6" , bandsawn to about 17" diameter. Rough turning was easy in this configuration. Of course, I could make it dance all over if I wanted to, but being able to slow this down to as low as 58 rpm made it safe. Speed control is attained by turning a knob, no belts to change, just speed it up or down to where you want it. Look at how much swing room is left. I would need a hoist to load up a piece that big.
Pic 3, the spindle, is a cane I made and posted here. http://lumberjocks.com/projects/34710
I used a forstner bit in a jacob's chuck to bore out both ends. It was easy and safe to do. Fun, too.
The indexing was used to layout the twist on the cane, along with the spindle lock to lock the piece in position for shaping after the turning.
I also used those features for this: http://lumberjocks.com/projects/34144
This is a stable platform for this type of work. Lots of room to get in there, I can rotate it where I need and then lock it down.
The control box is a great feature, just put it where you need it to be.
One thing I really like is being able to turn from both sides. I have found that in certain situations, I get much better access to the workpiece from the other side. It's simple to move the toolrest, start the motor in reverse, and have the control box right where I need it.
I have 2 more pics in My Workshop.
I have seen others review and recommend the tool rests that Robust makes, and I agree. The rest of the lathe is at the same high standards and quality.
They are good folks to deal with, and they make them in Wisconsin, USA.
Here's a link to Robust: http://turnrobust.com/Index.html
Watch the videos.
  • Like
Reactions: marcbousquet
#5 · (Edited by Moderator)
That's a nice lathe. I've never seen that one before. I too will be moving up to a bigger lathe some day and am already eying choices.
So let me ask you this, not knowing anything about it; let's say you have a 24" platter chucked up with the bed removed. Can you get in close to the center of the platter with the removable bed on the side and the gap between the platter and the fixed bed, what, 12 inches away? You know what I"m saying? Can you hook the toolrest up to the fixed bed parallel to the ways as an extension to get in there? Otherwise you're going to need an awful long tool rest.
#9 · (Edited by Moderator)
Those are great lathes….very well built, you will have it for a long time. I have used one a time or two and they reallly make turning so much more pleasurable. I am envious of your new lathe and your retirement….but \ am looking forward the the beautiful pieces you will be able to do with more leisure time.
#11 · (Edited by Moderator)
Boy howdy, when you treat yourself you do it in a big way. That lathe looks like one really fine machine that will give you many years of fine service. I pray that you will have many wonderful years of retirement so that you can play with that beautiful machine. Congrats and thanks for posting this.
#15 · (Edited by Moderator)
Well I must say you got yourself a doozy! I think that if I had seen that one when I was looking for my lathe, I might have ended up with it instead of my Powermatic, not that I have anything against my sweet machine, I just think this one has better features. Enjoy your retirement, you are stepping out in the right direction! Just be sure to wear a full face shield everytime you turn, I had a couple pieces fly off and land on my faceshield! Whew!
Erwin, Jacksonville, FL
#17 · (Edited by Moderator)
I've had it 7 years now. The only problems I had were operator error. No parts replaced. I seriously boogered the threads on the tailstock quill while drilling , totally my fault. I sent an email to info@robust.com and explained what happened and that it was my fault. They had me send it to them. A few days later it was in my mailbox, good as new, no charge.
It is still as good as new.
Here's a pic taken 10 minutes ago.
#19 · (Edited by Moderator)
I have the wheel set. The version I have is different than the current option. It's simple to put on, move and remove when needed.
Mine has a lever jack, similar to the kind used to get a motorcycle wheel up high enough to change a tire.
The current version uses a screw jack.
2 strong bodies can move it into a basement, 3 is better. Mine is in my basement, down the steps.
Robust has a PDF on their webpage about moving a Sweet 16. http://www.turnrobust.com/faq-2/ This PDF wasn't available when I moved mine, so I did it differently.
If you have wooden steps like mine, I suggest reinforcing them before putting a lot of weight on them, at least take a good look first . I added screws to the nails holding the steps together, and built a 2Ă—4 framework under the steps for more support. The framework became shelving .
I used a hydraulic motorcycle jack and an appliance dolly. I took off the bed extension, banjo, tailstock and the racks at each end of the lathe, picked it up with the motorcycle jack and removed the legs. Then we lifted it off the jack and placed it on the dolly, strapped it down, went down the steps, and set it back on the jack to install the legs. I attached the casters while it was still off the ground, set it on the wheels, moved it in place and removed the wheels.
One good thing about the motorcycle jack is once you have the lathe on the ground without wheels, you can adjust the height to where you want it.
Say hey to Elly May for me!
