Replacing the cutting head on a Ridgid R4330 with a Shelix head
Tags
planer
19K views 28 replies 11 participants last post by  b2rtch
#1 ·
Replacing the cutting head on a Rigid R4330 planer with a Shelix cutting head
The first thing I want to say is: Shame on Byrd tools for not providing one word of instruction with the head or on their website.
There is instruction with the head but they do not at all refer to this planer and I could not finds any instruction referring to this planer on their website.
One pays well over $400.0 for this head and he/she is left on his/her own.
This is not right!
Be very careful while handling this head, the cutters are razor sharp
This why I write this blog, to help others who would want to do the same thing.
If you mechanically inclined you can do this.
It was more difficult for me because I had to figure out everything.
I received the head from Holbren this afternoon
With head , I received a torx wrench, spare cutters and instruction to replace the cutting head on a Powermatic planer or any other generic large 4 posts planer but nothing relevant for the Ridgid R4330 planer.
I am on my own.
This is the original cutting head
My first challenge, and may be the most difficult one ,was to find out how to remove the side plastic covers.
The top one is easy the figure out, the side ones are more difficult. There are four screws on each sides behind the elevation screws.
The easiest way to get to these screws is to put the planer on its sides
After these covers are removed everything else is quite easy.
I mark with a paint marker all four posts, the top "frame" and sides, to put them back in the same position.
Then I removed all four post and the top frame.
This step might not be necessary.
The elevating mechanism may be removable with out removing the top frame,I am not sure
The elevation mechanism need to be removed to access the driving pulley behind it.
The bottom chain driving gear must be removed before removing the elevation mechanism.
Then all the elevation mechanism can be disassembled and taken out
The nut on the driving pulley is left hand threaded
After removing the pulley the screws retaining the bearing cage,can be removed.
The red lever is the shaft locking lever, it will not be reused.
After removing the screws, the cutting head easily comes out.
Putting the old and new head side by side , I at first believe that I received the wrong head as it has no driving gear to drive the rubber rollers.
I contact Holbren which tells me that the at the gear in fact seems to be screwed in the shaft.
I tried and they are correct the gear unscrewed, in fact the gear was only about finger tight!
I screw the gear on the new shaft quite a bit tighter than it originally was.
I remove the cage off the driving side bearing and I install it on the new head
I instal the new head on the planer, I use the three screws on the cage to "press" the shaft and bearings in.
The new cutting head is in and it rotates freely
I notice that the rubber rollers are dirty , this is good time to clean them
Upon reassembly I notice that I misplaced the key for the driving pulley. A kit from Harbor Freight saves me.
This also is a good time to adjust the tables.
I finished the reassembly with out any challenge.
I lubricate the screws and elevating mechanism with dry molycote.
The operation of the elevation mechanism is now much easier and smoother.
First try.
I pick a piece of ash wood to try the head
I plane first in one direction then the other direction, very little tear out
The shaving are very short.
I notice that the motor sounds like it works quite a bit harder than with original head
I want to say how impressed I am by the quality of fabrication of this planer.
The quality is excellent.
Congratulations Ridgid
#2 ·
This is not right!
I am on my own.
First try.
Tx for the instructions but I do have a question
What made you invest more than $400 in a planer that is less than $400?
#3 ·
This is not right!
I am on my own.
First try.
There is no 13"planer with an helical head available on the market.
Tired of replacing the knives
Quality of cut
Mostly because I love to tweak my tools.
#4 ·
This is not right!
I am on my own.
First try.
when you say:
I notice the motor works quite a bit harder than with original head
do you mean it actually has less power with the new head
i am trying to get one for my delta DJ-20 jointer
(i ordered one six months ago
but they finally told me they didn't have one for 3 months)
i read also most don't come with the bearings
but don't seem to offer them
or say what pert # or where to get them
can you explain about this please
i'd hate wait again for so long
just to have to find the bearings and wait for them too
thanks for the good photo post
give a much better idea what's involver here
#5 ·
This is not right!
I am on my own.
First try.
Patron you are welcome.
My head came with the bearings as did the head that I installed on my Powermatic jointer.
I can hear the motor working harder,as if I was taking a heavier cut.
Part of it could be the wood, I normally work with Douglas Fir and not with Ash Wood
Questions are welcome
#6 ·
This is not right!
I am on my own.
First try.
thanks bert
i guess when ordering
a call to them too
would clear some of this up
right away
i'm guessing the woods do have something to do with the motor strain
as with just about all the tools we use
#7 ·
This is not right!
I am on my own.
First try.
I got my head in just two weeks.
I ordered it from Holbren
#8 ·
This is not right!
I am on my own.
First try.
How does the new cutter head perform? Is the quality of the wood surface up to your expectations?
#9 ·
This is not right!
I am on my own.
First try.
@b2rtch
I was not aware you could not find a 13" with helical head. Tx for the info
Good luck in your installation and let us know how it performs.
#10 ·
This is not right!
I am on my own.
First try.
It performs very well.
As every one knows the Shelix cutting heads live no or very little tear out and a very smooth surface.
Steel City sales a 13" planer wit a head that they call "helical" but in fact it is not helical and the quality of cut is quite bit inferior to the Shelix cutting head.
#11 ·
This is not right!
I am on my own.
First try.
lepel
here is holbren that sell them
they have them in many sizes for different tools
#12 ·
This is not right!
I am on my own.
First try.
You can also buy them for a little less money at Global Tooling :
http://www.globaltooling.com/
http://globaltooling.bizhosting.com/products/heads-journal/planer-journal-heads.html
#13 ·
This is not right!
I am on my own.
First try.
Great post, Bert. What did you use to clean your rollers? I've considered doing it, but I've always been a little concerned about damaging the roller material with a solvent if I didn't have confidence that the solvent was the right one.
#14 ·
This is not right!
I am on my own.
First try.
Very nice review with great photographs. My experience was the Shelix is substantially quieter and easier on the motor, so your comment that your motor sounds like its working harder is puzzling.
#15 ·
This is not right!
I am on my own.
First try.
The cutting head itself is much quieter but the motor seems to work harder.
To clean the glue from the rollers I first tried Isopropyl alcohol but it did not work.
I then used lacquer thinner. It worked without damaging the rubber
#16 ·
This is not right!
I am on my own.
First try.
might be the extra weight in the shelix itself
all the screws and more cutter knife's
#17 ·
This is not right!
I am on my own.
First try.
I believe that, as other have been writing before me, that the difference is that cutters are cutting at all time( there is always a cutter, or more, in contact with the wood) when with the straight blades, there is small laps of time during each cut.
In addition the mechanism of the cut it different, a straight blade cut straight into the wood much like chisel or a plane, these cutters have shearing action.
#18 ·
This is not right!
I am on my own.
First try.
Bert, Thanks for a great blog. I'm still not clear on where the screws that hold the plastic sides are. You are a much better tool mechanic than I for sure. Not sure I could get it back together (but I'm keeping this blog for reference).
#19 ·
This is not right!
I am on my own.
First try.
gfadvm, you could do it, it is not that difficult and I can answer your questions
The screws are inside the planer in the four corners behind the vertical screws which suppor the whole cutter head/motor assembly.
If you lay the planer on its side , they are much easier to see and to reach
#20 ·
This is not right!
I am on my own.
First try.
Thanks Bert, I would like to remove them just to clean and service it as I can't afford to upgrade the head at this time. Maybe doing this would give me the confidence to attempt what you have done.
#21 ·
This is not right!
I am on my own.
First try.
Bert, glad you figured it out.
Did you go to their website, they recommended, and check out the instructions for the generic 4 post install?
They probably don't have enough people replacing their Rigid machines to warrant a special category if it fits in the generic column.
#22 ·
This is not right!
I am on my own.
First try.
The problem is that the generic four post machine like the 15 or 20" Grizlly or Powermatic , have nothing to do with the Ridgid.
One who works on a Rigid is on his own, until now.
#23 ·
This is not right!
I am on my own.
First try.
gfadvm, the filth picture from the top, attempts to show one of these screws
#24 ·
This is not right!
I am on my own.
First try.
Hi:
I looked at the Byrd web sit and was surprised that there was not any instructions for you machine. It did show a Rigid set of instructions. That being said, it looked like the other bench top planer that they have instructions for would help you. I hope you looked at them.
I put the Byrd head on my 15" Jet thickness planer. The instructions were very good. My planer runs quieter and makes a lot less noise and sounds like its not working as hard. The chips on my planer are much smaller than yours. The only thing I can say bad about the cutter head is I am sorry I did not know about these heads sooner. Like you said no chip out. Some of there heads are sold by Grizzly, and they are cheaper there. I have talked to Byrd them several times because I have a old jointer and wanted a Byrd head on it. They were very helpful and the head works great.
http://www.byrdtool.com/ I have shown there home web sit for you and others can get these great cutters.
#25 ·
This is not right!
I am on my own.
First try.
Bigrock, "It did show a Rigid set of instructions".
Where?
I just look again and I cannot find anything at all
The Shelix heads are also available for a little less money from
http://globaltooling.bizhosting.com/products/heads-journal/planer-journal-heads.html for a little less money
#26 ·
This is not right!
I am on my own.
First try.
Hey Bert great job!! Your blog will be a big help to the Rigid owners.
