Hi Folks,
I am making kitchen countertops using white oak. So far I have just used General Finishes gel stain followed by several coats of Arm-R-Seal. For the top that holds the sink, I would like to fill the grain a bit more against the moisture it will surely get.
I have not been able to find a single article, from General or anyone else, about the sequence of that. Tonight I'll try a clear Z-poxy resin fill on scrap with plans to sand that back to wood and then apply the gel stain over it. I don't see a way around that sequence since the filler has to be flattened which would wreck the color if it was put on first. On the other hand, the clear filler will keep the stain from getting into the pores. I might dump a little stain into the epoxy on another piece to see if it will dry.
If anyone has experience with grain filling using those two General products, I'd love to hear how it worked for you. Thanks, sh
