Im building a large walnut vinyl record cabinet, approximately 30" tall, 60" wide, 20" deep. The cabinet will have mitered corners, and two center dividers. Its a fairly large piece.
I am planning on pre finishing all of the components before assembly to make things easier on me. I will be spraying conversion varnish.
When I assemble the piece, I will be using temporary glued on blocks using the blue tape and superglue method to clamp the mitered corners together.
My question is, should I prefinish both sides of all components, or just the inside faces, and finish the outside after its complete. Even though there will be tape between the sacrificial blocks, I dont want to mess up the sprayed conversion varnish finish. However, on the flip side, I am worried that If I only spray the inside I have to worry about the pieces warping.
How would you guys tackle a piece such as this?
