Hi,
I'm about to make a new TS sled and pretty much every single howto I've seen uses hardwood for the runners except for one where the guy used ply. Now the thing is, most videos where they used hardwood came with a warning about wood movement or the complaint that the sled was no longer used because either it binded or had too much play.
In light of that I was considering using ply, but wanted to check with the forum before doing that as there must be a reason why almost nobody seems to be going that way.
Also another idea I got from a completely different project was to use HDPE, the kind often used in chopping boards, seems to be hard enough, resistant and good at sliding with minimal friction.
thoughts?
thoughts?
