Oily Rags video
3.6K views 19 replies 17 participants last post by  Knothead62
#1 ·
Go watch a video that “Burbon Moth” put together about fire in the workshop.
He is on You Tube. His test on oily rags is very interesting. I am sure that everyone will have a new appreciation of how dangerous oily rags can be.
#3 ·
In spontaneous combustion, as linseed oil is a natural product, a pile of rags soaked in linseed oil will start to compost, decay, and that will lead to increased temperature until the flash point of linseed oil is reached. Back in the day most if not all paints were made as a combination of linseed oil, mineral spirits, and white lead paste. My wife's grandfather was a house painter and according to his son, he never bought a gallon of ready-made paints. Grandpa always stored his oily rags in a steel container with a lid.
#18 · (Edited)
That is a cool book, J. Amazon has it for 12$, think I will get me a copy.
I betcha practically no one paints the underside of porch flooring anymore.
I read books quite often and develop in this direction, I have been doing this for a long time and write various stories. Although I read a lot, sometimes I have problems with it and I use EduBirdie to help. This is a great resource where everything is done quickly and efficiently.
Great book, thanks for the gift! I liked her too.
#8 ·
No, it cannot spontaneously combust after the oil is dried. When linseed oil dries, it reacts with oxygen in a chemical reaction called oxidation. This chemical reaction is exothermic, meaning it generates heat. Once the oil is dried, it is completely oxidized and no more reaction will occur. Wetting it makes no difference, neither is it necessary to prevent spontaneous combustion. If oily rags are dried flat and not crumpled, there is not enough heat generated to induce combustion.
#11 ·
I never wad up rags. I have old rags for changing the oil in my mowers. I always lay them our flat on a concrete floor or drape them over the handle of a hand truck. I also turn pens and have loads of paper towels with CA glue on them. I toss them on the concrete floor to dry and "defuse." Never in a pile. I have also put them in a can of water.
#17 ·
The speed at which this can happen may be a surprise to some. Had a technical position with a resin manufacture. Major customers were coatings coatings mfrs.
During a delivery of bulk linseed the truck driver followed all procedures properly. After emptying the delivery hose he used a rag to wipe any drips from both the truck connection and the hose end. He the placed this balled up rag on the trailer’s fender, in the sun and went to double check that all valves had been closed properly. In less than 5 minutes when he returned to the fender area of the trailer the balled up rag was smoking profusely. This was in the Northern US and the ambient temp was approximately 50F at the time.
#19 ·
Simple Common Sense....Unless you are in such a rush...just spread the rags out until they dry. fold them back up until needed again..
Otherwise...you WILL be in a rush to call 911.
Take the time to do it right. The Dungeon Woodshop ALWAYS spreads out any oil soaked rags flat on top of the tablesaw, when I am done.
Maybe instead of spreading all this "it will BURN THE HOUSE down.." stuff..maybe post how to prevent such things...
