1. To know when to let off the trigger when joining with pocket screws I watch the joint. When it butts up tight you re done.
Tip: Get your self a impact compatible with your drill/driver. Most manufacturers offer one. They generally produce 3x the torque of the drill driver made by the same manufacturer. You will strip out less screw heads and gain a new level of control and "feel".
2. Different species of wood will yield a different feeling of joint strength. A pocket hole joint made with Spruce Pine Fir (softwood) will not feel has strong as one made with Ipe (hardwood).
Most of the weakness felt in your joints is because of the design shown in your drawings. I realize you said you were going to add stretchers to the lower portions of the legs, that will help a lot.
3. Check your drilling jig thickness settings. Remember, the pocket hole jig is setup so the screw exits the center of the board the screw is placed in. You might back it off a little, set it for a thinner board to give yourself more room screwing into the board that you re joining.
And, don t forget to use glue when making pocket hole joints.
Another pointer for future framing designs. Wood used horizontally should be supported by wood used vertically.
Do not rely on mechanical fasteners where weight is to be supported. Joist hangers are about the only time you can get away with using mechanical fasteners to support weight. In that scenario you should be using structural grade nails or screws only.
Here s how that applies to your drawing;
Front/back: Cut the top board 21" long, making the top edge of the board 18" long, centered. This will allow the board to rest on top of each leg. Drill a pocket hole at the end to join the 24" side board. Cut the lower stretcher 18" long. Place where at a desired shelf location. I would use a set of pocket holes at each end to join to legs.
Sides: Cut the top board 24" long, making the bottom edge 21" long, centered. This will allow you to have both the front and sides supported by the legs and still allow for using two pocket hole locations at the legs. Cut the lower side stretchers at 21" long simply butting the 18" front/rear stretcher, place one screw through the front/rear stretcher into the side and then two screws through the side stretcher into the leg. Glue and screw plywood to the top of the stretchers forming a lower shelf inside of the legs.
Using the stretcher lengths I described you could not put a lot of weight on the lower shelf because it is merely supported by screws. If you needed a shelf for heavy items you could notch the legs and then lengthen the front/rear stretcher accordingly.
- devann
Thanks for your reply! Just to give a bit more information on my project, I am building a stand that will hold two 16 gallon water containers that will be used for making saltwater for my aquarium. So you should think of this as garage type furniture. This is why I am just using plain 2×4s and b/c 3/4" plywood. Each container will weigh something like 140 pounds when full of water.
Ok, here are my comments to yours and some further questions…
1. I wonder if I am clamping the pieces together too tightly while I am installing the pocket screws? Could this keep the pieces from joining well?
Also, what size drill would you recommend for this task and for general woodworking? My plan after building this stand is to build some shop furniture / cabinetry out of 3/4" plywood, a bench for our front porch and then we will see from there. Most likely I will focus on plywood cabinetry and some small hardwood tables. Currently I have a Craftsman corded drill that I use for drilling the pocket holes and then I have a small Ryobi 12v cordless drill that I am using for installing the screws. I wonder if I need a larger cordless drill?
2. I suspect that the joint movement may be due to the fact I am using plain 2×4s, which I believe are cut from soft wood, correct? And please see drawing below. Is this better? Should I add anything to the back? Maybe a stretcher on the back?
I don t really follow your comments regarding "top edge" / "bottom edge." Please see the drawing below and let me know if you would make changes here. The way I was thinking about this was the the side rails will rest on the legs and provide the top down support. The front rails will simply join the left and right side structures and hold them together. and then the 3/4" plywood top would hold it all together as well. I would also add something to the back.
On the drawing, some of the measurements are very slightly off as I am new with sketchup.
Thanks again for your help!
- pcox
