Need advice for making an outdoor bench
1.7K views 4 replies 3 participants last post by  uffitze
#1 · (Edited by Moderator)
I am wanting to make an outdoor bench from a couple of walnut slabs that I have had for about ten years. The slabs are approximately 7 feet long and still have the bark on them. I kept them after having a large black walnut tree milled, never knowing what I would use them for until recently this idea struck me. One slab is approximately 4 inches thick in the middle and the other is is approximately 3 inches thick.
I want to use the 3 inch thick slab for the back support of the bench and the 4 inch slab for the seat. I am wondering if I should leave the bark on or find a way to shave it off. I am going to attach the back support to the seat obviously but am having trouble finding the right angle to put the back support at.
My biggest question is how do I smooth the surface of the wood? I do not have access to a planer or sander big enough to handle these slabs and doubt either would work because of the curve of the would on the back side. I thought about building a carrier for my router which would ride on rails as I made passes over the wood slabs (using a flat cutting bit and making several passes). My thought was the wood slabs would be sitting on my bench or saw horses and secured so they would not move.
I am going to make legs for the bench by using some small branches about 3 to 4 inches thick. I have not completely figured out the best way to attach the legs yet.
Can you guys/gals give me any advice on planing/smoothing out the wood? Please throw any thoughts you have out there for any part of it. I am probably going to use a spar finish on the wood, will this work for the bark side or is there something better to use?
Thanks for any advice offered.
#2 ·
This is ironic. In another forum subject we are commenting on what purpose a hand held power planer has for a woodworker and the consensus is "not much". Now, your situation may be the perfect place for a hand held power planer. I would opine that for this application you don't need to get the surface perfectly flat. Just close would be good enough. You can probably get there with a hand held power planer followed by an aggressive sander.
Speaking of sanding - If I want to remove a lot of material in a hurry, I use my handheld belt sander and a 40 grit belt.
Regarding the angle of the back, most casual chairs and benches usually 12 - 15 degrees off of perpendicular.
Regarding the bark - - It's going to come off eventually unless you permeate it with CA glue which would be a big job for a project like this.
#5 ·
Well, any wood exposed to the elements is going to fade in color. You may be able to reduce some by using a good spar varnish, but you will also have to keep on top of maintaining the finish.
Other than fading, I'm not sure how it will respond to the elements. I am aware that "Brazilian Walnut" is sometimes used for decks, but I don't know how that wood compares to black walnut.
My primary concern though is that I wouldn't want to use such a pretty and expensive piece of wood for an outdoor project that I'd only use part of the year, would be exposed to freeze/thaw cycles, and that I'd have to have to work on every couple of years to keep looking good.
