Hi.
I'm not a professional wood worker, but we just installed unsealed wood counter tops in our kitchen and the wood itself is bubbling up when water has gotten on it.
A little background:
These are new countertops but I've been oiling them with mineral oil when I could during construction before we moved in. I poured the oil on heavily and let it sit to soak in and would try to do this about once a week (the work going on around it made this difficult or I would have done it more often). I've also oiled them a few times since we moved in a week ago.
We've had wood countertops for the last seven years in our old house and never had this problem.
I guess a plumber was working on our sink and left a puddle of water on the counter for about an hour or two. The wood turned white (quite normal) but then raised up. If you ran your hand down it there was a pronounced bump. Now another spot where water sat, this time for a much shorter period turned white and then also bubbled up.
This never happened on our counters in the last house. We'd have things turn white if it was too dry or turn black if we weren't cleaning up the water enough but we never had the wood expand.
Thoughts? Answers? And does it go away with multiple oilings?
I made a mix of beeswax and mineral oil to use rather than just straight oil because I find that no matter how much I wipe the oil away the next morning it seeps into any paper you have on the counter. I'm hoping that helps but I'm finding that really annoying too.
Help!!
Thanks,
-Nanci
Help!!
Thanks,
-Nanci
