Got this bad boy (Sears Craftsman 149.23871) off of Craigslist for a steal about a month ago. The only thing wrong, other than needing a little TLC, was it didn t have the rear tail stock live center. After extensive research, this seems to be a common issue, hind sight is always 20/20.
Anyone who knows me will tell you that i m probably too stubborn for my own good. I decided that it shouldn t be TOO difficult to fabricate my own piece. I ll skip the first couple of prototypes and go straight to what i hope will be the finished piece. I took a block of aluminum and tapped a 1/2" thread in the center to attach directly to the tail stock. Then I used an old bearing bracket I had and mounted it to the block with a 3/8" bolt locked into place. This allowed me to thread on the #2 Morse Taper I had purchased.
To my surprise, the new piece aligned perfectly without any modifications required.
I haven t tested it out yet, I only just finished it, and figured the neighbors wouldn t appreciate my 1 A.M. projects. What do you guys think? Good idea? Or should I wear some body armor before turning it on?
- Rus2248
