Hi all. I picked up the cordless Makita track saw recently since I couldn't stand ripping sheet goods with my loud, dust-storming, garbage of a circular saw and don't enjoy trying to wrestle them onto my table saw, even after they're partially rough cut. I really want to be in love with it since everything I've read or heard makes it seem like the perfectly elegant solution to my problem. I've also invested A LOT to try to take any of the remaining frustration out of it and make it every bit the solution it can be, getting TSO's GRS-16 and 2 55" tracks with the hardware to join them together.
But… so far it's been nothing but a source of frustration. 20" cuts can be out of square by more than 1/16". I get a 1/16" notch at the very end of every board I cut. The splinter guard had all kinds of different widths up and down the track. I thought maybe I hadn't tightened the wiggles out enough, so after tightening it up and ensuring ALL the side-to-side play had been taken out, I replaced the rubber zero-clearance splinter guard on a nearly brand new track hoping for a fresh start.
I put it in scoring mode and ran it most of the way down the track, keeping enough on the front and back so that it wasn't running off the track at any point. Then I used that reference to make a cut on a piece of MDF, only to have another 1/16" disappear from the splinter guard, meaning my cut was also short by about 1/16" and the piece ruined. Then I made another cut, and MORE of the rubber disappeared. I am being very careful not to put any kind of lateral pressure on the saw that would it to skew at all.
Am I broken? Or just broke?
